FSB warrior
it should say on the emissions sticker what base timing is. I dont know what yours is, but mine is 13.... its highly modified though.
Charlie don't surf..
'92 Ford Bronco XLT
I thought base timing was 10 degrees for the 302.
FSB warrior
THats why I said check the sticker, it also tells you what to gap your plugs at... but that goes out the window too when you install an ignition.
Seriously the place where I bought MY engine from said 13 initial 31 fully advanced... so I do that... getting the curve set up has been the hard part. So unless you happen to have a CCM GT-40 LB then go with what the sticker says
