yo,
I have some upgrade LINKs in my site @
http://www.broncolinks.com/index.php?index=75
such as;
for example;
Terminals, Late-Model OE-style pic; "...The "lead-free" description is misleading. The other solder-on terminals are also lead-free; they're brass or copper with a tin or silver-solder coating. But this style may be a better fix if the damaged terminal is this style since it can merely be unbolted & replaced (no soldering) if the original ring terminals are undamaged. If these new ring terminals must be soldered on, the wires should be cleaned & tinned (coated with fresh solder) first. Then these rings can be crimped on & soldered to the tinned wires..."
Source: by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/registry/media/726315Battery Cable Positive 14431 (WC-8702)
92-96 Battery & Starter Wiring
IF THE IMAGE IS TOO SMALL, click it.
1 Cable Assembly 14B060
2 Cable Assembly (Lightning) 14B060
3 To Heated Oxygen Sensor for 5.0L/5.8L Under 8500, 4.9L, 5.8L (Lightning), and 7.5L F-450 Only
4 Bolt 56558-S 26-34 N-m (19-25 Ft-Lb)
5 Starter Motor 11002
6 Nut and Washer Assembly N805403-S100 10-14 N-m (8-10 Ft-Lb)
7 Screw and Washer Assembly 390926-S36 for All Gas, Except 7.5L Manual Transmission which use Screw 389883-S36 19-26 N-m (14-20 Ft-Lb)
8 Starter Motor Relay Assembly 11450
9 Nut and Washer Assembly 381561-S36 7-9 N-m (60-82 In-Lb)
10 Screw N803991-S36 4-6 N-m (35-49 In-Lb)
11 Cap 14A396
12 Star Washer 34943-S36
13 Existing Gas Vapor Tube 9S286
14 Battery 10655
15 Nut 33799-S2 (Auto Transmission) 11-16 N-m (8-12 Ft-Lb)
16 Cover-Starter Solenoid (Red) 11N087
17 Stud N806925-S36MG
18 Chassis Ground 14301
19 Bolt for 14301 Frame Ground 390158-S36 11-16 N-m (8-12 Ft-Lb)
20 Heated Oxygen Sensor Wire Assembly 9F472
21 Exhaust Pipe 5A212
22 Wire Assembly 12A690
23 Starter Solenoid Heat Shield (5.0L/5.8L Only) (Part of 11002)
24 Frame 5005
25 To Engine Ground 14301
26 Nut N621906-S36
27 Body Grounds 12A581
28 Engine Block 6010
29 Engine Bay Harness to Power Distribution Center 12A581
30 Alternator Harness 14305
POS = heavy Red circuit from battery Positive to starter relay, starter solenoid, alternator, and power distribution center
NEG = heavy Black circuit from battery Negative to frame, block, and fender
SOL = medium Red circuit from starter relay to starter solenoid
SEE MORE @
http://www.supermotors.net/registry/media/828671
by Steve83
btw, Inspect Battery tray & wrap-around insulation "blanket" too; they are available
Cable Soldering
Source: by Ryan M (Fireguy50) at
http://fordfuelinjection.com/?p=59
http://www.broncolinks.com/index.php?index=142
Battery + Cable Replacement in a 96 5.8
60" battery cable 4 gauge
32" battery cable 4 gauge (
upgrade)
4'6" section of 10 gauge wire (upgrade)
1 quick disconnect 12 - 10 gauge
1 ring terminal 12 -10 gauge
1 battery terminal (w/wing nut)
Upgraded to 2/0
Source: by JMac96 at
http://fullsizebronco.com/forum/showthread.php?t=152889
Slow Cranking or a Grinding Noise; "... Problems with the negative battery cable is a major cause of starting problems in Ford, Lincoln, and Mercury vehicles. Bad battery cables can cause slow cranking or a grinding noise when trying to start an engine. On some late model vehicles dating back to 1994, the wire connection inside the battery terminal connector corrodes easily. This will cause a voltage drop in the cable and result in low voltage being supplied to the starter. You can check for voltage drop in the cable using a digital voltmeter. Connect the negative probe of the voltmeter to the negative battery post (not the battery terminal connector). Then connect the positive probe to the starter case and crank the engine. The voltage reading should be less than .5 volts. A higher reading means there is resistance in the cable or the battery terminal connector. Clean the cable end and the battery terminal connector and test again. If the voltage reading is still higher than .5 volts, replace the cable and the battery terminal connector..."
Source: by genco1.com
Terminal Grease TSB 98-24-6 for 81-96; "...Ford Motor Company has released a new Electrical Grease (F8AZ-19G208-AA) to reduce the possibility of moisture corrosion at the terminals..."
Add the new grease during electrical connection repair.
CAUTION: ELECTRICAL CONNECTOR GREASE SHOULD NOT BE USED IN HIGH VOLTAGE CONNECTIONS FOR SPARK PLUG AND COIL WIRE APPLICATIONS.
Proper Uses Of The New Electrical Grease Include:
Electrical Connectors
Battery Connections
Light Sockets
Starter Terminals
Do Not Use On:Spark Plug Wires
Coil Wires
Spark Plug-to-Coil Connections
Low Current Flow Switches (12V Systems less than 0.1 amp) Source: by Ford
Ford has some lengths for the OEM exact replacement; but for those cables that have sharp/many bends, you will need to make them a little longer;
see Ford's MC and OEM brands Parts site @
http://www.fordparts.com
Select Model and go thru the drill
Electrical, Charging and Starting
Battery and Related Components
5.8L; 56'' long - 4 gauge
then click on "View Image" to see it and other cables to relay, starter...
an Image example is attached below
Ford Motorcraft® (fordinstallersupport.com) - Rotating Electrical (Starters, Alternators, Window & Wiper Motors, etc.), Ignition Components, Wire & Cable, Battery Cables, Windshield Washer Pumps, Wiring Harness Accessories, etc. Parts Catalog, Bronco/Ford truck & all Fords w/Ford Part Numbers, Illustrations & Cross References (54 MB pdf)
http://www.fordinstallersupport.com/files/catalogs/ewc200.pdf
Not much help here in lenght; but does show somew stock OEM Gauges such as WC-9033
48" — No. 4 Ga.
Ref. IIIus. 10 on page 317
Battery Cable (+) to starter
Bronco 1993
F Series 1993
page 321
Check Grounds;
Location pic, 1/0 under the AC Compressor pic in a 93
Source: by nemean at
http://www.supermotors.net/registry/media/562810
Intake Manifold to Block Strap Location pic in
Source: by boss (bossind, Steve) at
http://www.supermotors.net/registry/media/768672
Location, Frame & Battery pic in a 94 5.8; "...Frame ground just inboard of the R spring tower. The black battery wire goes from the front bolt of the engine mount (on the block) to this tab & up to the battery post, where a smaller black wire goes to the core support, providing a continuous ground path between the engine, frame, battery, & body..."
Source: by CodysBigBlueBronco (how much $???) at
http://www.supermotors.net/vehicles/registry/media/309108
Location pics in a 92
Source: by Jeremy M (Big '92 jermil01) at
http://www.supermotors.net/registry/2896/76377
G101 front of engine compartment, front of fender apron (D1) - RH = Passenger side mine has 2 small black wires between starter relay & headlight; this is #5 in the diagram; G100 & G104 (tied together in diagram); G100 @ LH front of engine compartment, on upper radiator support; G104 @ Rear of LH fender apron near hood hinge and 4WABS Test Connector (RED); G100 Serves Component, LH Oxygen Sensor, Fuel Pump Module, Inertia Fuel Shutoff, Misfire Sensor, Misfire Sensor Shield, Output Shaft Speed (OSS) Sensor, Powertrain Control Module (PCM) 5.0L; G101 Serves, RH Oxygen Sensor; G104 Serves Component: 4WABS Control Module, 4WABS Data Link Connector, 4WABS Relay #1, Instrument Cluster, Powertrain Control Module (PCM) 5.8L, Powertrain Control Module (PCM) 5.8L, Programmable Speedometer/Odometer Module (PSOM), Trailer Relay Box; G103 (battery to engine) Lower RH front of engine serves Component, 4WABS Pump Motor, Battery, Data Link Connector (DLC), Mass Air Flow (MAF) Sensor, Powertrain Control Module (PCM) 5.0L, Powertrain Control Module (PCM) 5.8L, Right Front Park/Turn Lamp, Right Front Side Marker Lamp Right Headlamp; G104 Rear of LH fender apron; G201 Behind bottom of LH cowl panel (driver's side kick panel),Component, Compass/Outside Temperature Module, Day/Night Mirror, Inside Cargo Lamp, Left Power Lumbar Compressor Motor, Outside Cargo/High Mount Stop Lamps, Right Power Lumbar Compressor Motor, Seat Belt Switch, Door Lock Actuator (PDL & Probably Power Window Motor); G200 Behind bottom of RH cowl panel serves Component, Air Bag Diagnostic Monitor, Electronic Shift Control Module, Instrument Cluster, Programmable Speedometer/Odometer Module (PSOM), Remote/Keyless Entry Module, Speed Control Servo/Amplifier Assembly; G103 (battery to engine) Lower RH front of engine serves Component, 4WABS Pump Motor, Battery, Data Link Connector (DLC), Mass Air Flow (MAF) Sensor, Powertrain Control Module (PCM) 5.0L, Powertrain Control Module (PCM) 5.8L, Right Front Park/Turn Lamp, Right Front Side Marker Lamp, Right Headlamp; G400 Rear Window Defroster @ LH rear corner of cargo area, near rear lamp assembly; Engine Block pic in a 94 5.8; G401 LH rear corner of cargo area, near rear lamp assembly (F9); "...The black battery wire goes from the front bolt of the engine mount (on the block) to this tab & up to the battery post, where a smaller black wire goes to the core support, providing a continuous ground path between the engine, frame, battery, & body; Frame & Battery pic in a 93; "...With the wheelwell gone, it's easy to inspect the frame ground, just inboard of the spring tower on top of the frame rail. The battery ground cable is stripped ~3/4" and a tab is soldered on so it can be bolted to the frame; Intake Manifold to Block Strap Location in a 96 5.0 is between 2nd & 3rd plugs on passenger side Locations & Components in a 96; SEE DIAGRAMS
Source: by miesk5
