1 - 3 of 3 Posts
Just a quick question i jacked the truck up to check for play in the bearings and if you push on the top they move about an inch. There should be no movement correct? srry for not searching , also the hub was really hot on the side i was checking while the other was not.
Administrator
push on the top of what?...if you mean tire than yes if you can move it an inch you have etheir bearing or balljoint problems.
Rest in Peace Friend...
Yes, any play in the wheel could be a bad bearing. Heat build-up is also a sign of a bearing problem. If it's hot to the touch, replace it. You'll prolly hear some grinding or screeching noises when driving by this time, too, if you turn the radio off, JSM84
1 - 3 of 3 Posts
