1 - 20 of 97 Posts
Past Bronco Owner
I started building my winch bumper. It’s not as much of a pain to cut up the ¼” plate with a 4 ½” grinder as I thought it would be. You do go through a lot of cutting wheels though. I bought another HF grinder for $17 so I could have one for cutting and one for grinding. I made a template out of hard board (peg board without the holes) for the top corners and started there. I also cut out the base plate for the winch.
Next I made the front plate for the fair lead and drilled and cut out the center. I tacked it to the winch base then test fitted it.
I cut out the front corner pieces and tacked them at a 90degrees. It starting to somewhat resemble a bumper.
At that point I ran out of cutting disks (10 so far). I went to HF and bought 20 more (plus a bunch more stuff including 4 more magnets $0.99 ea.) I then got side tracked looking for a upgraded CPU for my ‘puter. 2 Fry’s and PC club but no one had what I wanted (P4 478 pin 3.2Gz) by the time I got home it was past dark.
To be continued…..
Engineer
That does look good. Is it going to be flat across the front or angled back some at the sides?
Show us more!!!
Looks awesome so far. I like to see how everything is put together. Gives me a better understanding on how to make one myself. I am very interested in seeing how you mount it to the front of the truck.
Some assembly required!
Lookin good. MagnumPI's been talking to me about building him one kind of like that, I'm looking foward to seeing how yours comes out.
Past Bronco Owner
Discussion Starter #9 (Edited)
I had to help a friend setup a wireless lan so I didn't get started until 2:00. There is more there than it looks like though. Every mounting point is on a bracket than can be unbolted. I tacked the sides and back corners on, mounted each side in place with 3/8" x 2" flat stock and put a diagnal 1" square tube from the outer corners to a spot about 1.5' from the front of the frame.
It still might look a little funny since I don't have the bottom plates on yet. I thought it would be easier to brace it up this way.
It's a good thing I made it adjustable since I wan't thinking and set it up with a magnetic degree indicator at 90 degrees. I didn't take into account the angle of the driveway. Duh
It is easily fixed though.
to be continued.....
Engineer
Looks a lot like mine, very sweet. Might look more symetrical if the middle part was as wide as the grill but it looks good.
Past Bronco Owner
Discussion Starter #11
I wanted to tuck the winch in as tight as I can into the grill as much as I can so I made the winch box small enough to fit in between the frame rails. There will be a third angle between the corners and the winch box.
I'm not sure exactly how to describe it so stay tuned. Next weekend I should get more done.
Past Bronco Owner
Discussion Starter #12
I got a little further on the Beater Bumper. I also found out I didn't buy enough steel. I got it welded up enough to drive it back to IMS to pick up some more. It looks a little ugly right now. I will grind all the visable welds off and round off the edges.
If I'm lucky I should be able to finish it over the weekend.
Past Bronco Owner
Discussion Starter #15
I cut the stock brackets and welded a 3/8" x4" bar across them and went from there. I will be welding more 3/8" stock at a 90 degree for additional strength. I also have 1" square .120 wall from the top corners diagnal to the frame and will add more bracing before I'm done. I have to pick up some more steel tomarrow.
Yes the center does look inverted. I took a few pics and they al look that way. :shocked
Engineer
Looks good
Banned
vvery nice
that is a very nice bumper, that road armor dont have nothing on you, i like your design very much. keep up the good work
Ray
1 - 20 of 97 Posts
