1 - 8 of 8 Posts
Not sure if this is even possible or if im asking a dumb question. Always liked the broncos just not found many available but i was able to get this 1996 Ford f150 XLT 4x4 with the inline 6 engine. Exactly what I was after. Now I am not saying I am going to do this but I know its pretty simple getting these beds off since i have done it for exhaust work and getting rust off and repainting frame- BUT my question is what are the dimensions of this truck bed vs a Ford Bronco Truck bed? If i found one am i able to take it and swap it right out for the Bronco bed? Comparing pictures it doesnt look like it because the wheel well starts alot close on Bronco than my truck. Just curiousity more than anything. Any input would be great
A truck is a truck cab, & a bed.
A bronco is nothing like that, its all welded together like the body of a car. Here is a Bronco Body you can look at for reference. If you want a bronco, sell your truck & buy a Bronco, cuz what you are thinking is way off base.
The wheel base ( as you observed ) all by itself will prevent the swapping of chassis under the Bronco.
The Bronco and the F-150 are exact matches ( of the same generations ) from the rear edge of the doors then forward. Behind the doors and back they are different vehicles all together.
You can swap parts around from the doors forward, but not much else. Maybe the differentials are the same, not sure about that though. Everything else in the back is non compatible.
1982 FSB 302, c6, BW1356 manual, manual hubs, manual windows, 3.00 gears, 31x10.5 Kenda A/T
This is how you turn your F-150 into a Bronco like thing in six easy steps!
1. Buy a camper shell
2. Cut out the front of the bed
3. Cut out the back of the cab
4. Cut out the front of the camper shell
5. Put lawn chairs in the bed
6. Duct tape all seams between the cab, bed, and camper shell.
i knew some were like that but when looking at the one at the top of this website for example, it look like two seperate pieces. i know they have broncos made for seats but other broncos i thought were just standard truck beds. again i said it may be a dumb question i just wasnt sure if it was all solid piece or two pieces.
Yo MrGreenXLTm,
Welcome!
Here's the Bronco/F Series Workshop Manual, partial by Ford via
An excerpt;
"Section 01-04: Pickup Box
1996 F-150, F-250, F-350 Regular and SuperCab Workshop Manual​
REMOVAL AND INSTALLATION
Pickup Box, Styleside
Removal
  1. Remove tailgate from pickup box. Refer to Section 01-03.
  2. NOTE: Wiring assembly for the rear lamp (13404) must be rerouted through the tail lamp housing so that the wiring does not interfere with the pickup box removal.
    Remove rear lamps from box. Refer to Section 17-01 for rear lamp removal and installation.
  3. From underside of vehicle, remove six nuts attaching pickup box to frame rails.
  4. >Remove six bolts from pickup box. Note location of each bolt.
  5. NOTE: Because of the weight of the pickup box, it may be necessary to have two people on each side of the box to facilitate removal.
    With aid of an assistant, lift pickup box enough to clear the frame and remove from vehicle.
Installation
  1. Follow removal procedures in reverse order.
  2. Tighten the pickup box nuts to 54-95 Nm (40-70 lb-ft).
Pickup Box Installation, Styleside
171853
ItemPart NumberDescription
1N803023-S40Bolt
2N620483-S2Nut
3N803022-S40Bolt
4N803020-S40Bolt
55C036Isolator, Frame to Body
ATighten to 54-95 Nm
(40-70 Lb-Ft)"
96 F Series, Bronco vans and cars Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ https://www.fleet.ford.com/partsandservice/owner-manuals/
ASAP, find out if speed control, if equipped, recall work completed by dealership. Call local dealer or register and view status @ Welcome to Ford Owner | Official Ford Owner Site; or @ Recalls Look-up by VIN (Vehicle Identification Number) ... have VIN ready.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
Register with VIN to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site
96 F-Series/Bronco Workshop Manual (PARTIAL) via 1996 Bronco/F-Series Workshop Manual
96 F Series Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ https://www.fleet.ford.com/partsandservice/owner-manuals/
To chat about any issues or planned build, it's better to post each seperately in Noobie section. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view).
To save you time and for better responses, please fill out your trucks info with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
Our Forum faqs @ FAQ Includes for example:
How to Use Searchand more tips!
➡ Look at Baba Looey's Favorite FSB Links (lots and lots of tech links...
such as Info on adjustable Caster/Camber bushing., etc.
Try to find time to participate and VOTE in our Full-Size of the Quarter Contest & later in the year Full-Size of the Year Contest @ F.O.T.M Voting
You will get ideas by those competing.
Then get ready for the Full-Size of the Year (F.O.T.Y.)!
Al
No, all Broncos have a fixed "bed". It's all one piece from firewall to tailgate opening and people often refer to that as the "tub" like if they say they plan on swapping in a new "tub".
But for shizz and giggles, if you're wanting to know the size difference between your truck's bed and a Bronco's bed, I can probably give you a decent visualization.
My Bronco and truck are a little older than what you're looking at, but should be pretty close in dimensions. Your truck looks like a short bed, which for '96 is a 116.8" wheelbase according to google. My truck's wheelbase is 117" according to my warranty plate on the door. My 78 Bronco has a wheelbase of 104" (according to the warranty plate), so that's a difference of 13" in wheelbase between my Bronco and truck. Here's my Bronco's topper on my truck's bed. That's a rough visualization of how much longer your truck bed would be compared to a Bronco "bed".
But like everyone else has informed you, you can't just unbolt a Bronco "bed" and swap it to another vehicle. That'd sure make quarter panel replacement and lot easier though. lol
Yo MrGreenXLT,
Section 01-01: Underbody
1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
ADJUSTMENTS
Underbody Misalignment Check
The dimensions of the underbody must be restored in repairing major body damage to provide correct front and rear wheel geometry. Refer to the Underbody Dimensions diagram for the underbody dimensions. All the dimensions are detailed to the centerline of existing holes in the underbody assembly. Once the frame and suspension members are aligned, other operations in this section can be performed.
NOTE: All dimensions are true point-to-point in inches. Measuring can be performed using the Rotunda Complete Laser Measuring System 190-01025 or equivalent.
Door openings are checked in the same manner as the body. Horizontal, vertical, and diagonal checking points are established on all four sides of the door opening that is being measured.
F-150 Regular Cab Short Bed (4x2)
171879
MEASURING POINTS
Item Description
1 Bolt
2 Bolt
3 Stud
4 Bolt
5 Rivet
6 Stud
7 Rivet
8 Stud
9 Rivet
10 Stud
11 13mm (0.51-Inch) Hole
12 12mm (0.47-Inch) Hole
13 12mm (0.47-Inch) Hole
14 12mm (0.47-Inch) Hole
15 Rivet
16 11mm (0.43-Inch) Hole
17 12mm (0.47-Inch) Hole
18 Rivet
19 8mm (0.3-Inch) Hole
20 Stud
21 Rivet
F-150 Super Cab Short Bed (4x2)
171880
MEASURING POINTS
Item Description
1 12mm (0.47-Inch) Hole
2 Bolt
4 Bolt
5 Stud
6 Rivet
7 Stud
8 Rivet
9 Stud
10 7mm (0.27-Inch) Hole
13 8mm (0.31-Inch) Hole
15 Rivet
17 Rivet
18 8mm (0.31-Inch) Hole
19 Stud
20 Rivet
F-150 Regular Cab Short Bed (4x4)
171881
MEASURING POINTS
Item Description
1 15mm (0.59-Inch) Hole
2 Bolt
3 15mm (0.59-Inch) Hole
4 Bolt
5 Stud
6 Rivet
7 Stud
8 Rivet
9 Stud
10 8mm (0.31-Inch) Hole
11 12mm (0.47-Inch) Hole
15 Rivet
16 12mm (0.47-Inch) Hole
17 11mm (0.43-Inch) Hole
18 Rivet
19 Stud
20 Rivet
F-150 Regular Cab Long Bed
171882
MEASURING POINTS
Item Description
2 Bolt
4 Bolt
5 Stud
6 Rivet
7 Stud
8 Rivet
9 Stud
14 Rivet
15 12mm (0.47-Inch) Hole
16 8mm (0.31-Inch) Hole
18 11mm (0.43-Inch) Hole
19 Rivet
20 8mm (0.31-Inch) Hole
21 Stud
22 Rivet
F-150 Super Cab Long Bed (4x2)
171883
MEASURING POINTS
Item Description
2 Bolt
4 Bolt
5 Stud
6 Rivet
7 Stud
8 Rivet
9 Stud
10 12mm (0.47-Inch) Hole
11 Stud
15 8mm (0.31-Inch) Hole
18 Rivet
19 8mm (0.31-Inch) Hole
20 Stud
21 Rivet
F-150 Super Cab Long Bed (4x4)
171884
I
MEASURING POINTS
Item Description
2 Bolt
4 Bolt
5 Stud
6 Rivet
7 Stud
8 Rivet
9 Stud
11 Stud
17 Rivet
19 Stud
20 Rivet
171885
1 - 8 of 8 Posts
