1 - 20 of 25 Posts
1990 EB, 5.0
Today my serpentine belt came apart on me. It was getting chewed up and half gone by the time I made it home.
Figured it was old. I went to put in the new one, started the truck and it’s off a little on the smog pulley. I align it, start again and it’s off a little of the harmonic balancer. I align it, start up, it’s off again on the balancer. Try again. Still off on the balancer. Soon as I start up it works off the edge of the harmonic balancer pulley.
last month I replaced the power steering pump so I’m guessing that is where the misalignment is coming from. I assume I just didn’t notice until the belt got chewed up. Never had a belt problem before.
Also installed a K&N cold air intake 3 days ago and there is bracket that I attached to the ac compressor. Perhaps that the cause?
Any ideas before I begin troubleshooting?
YO Siggy,
  • Greatly misaligned pulleys.
  • CHECK for misalignment between adjacent pulleys.
  • Drive belt not seated correctly (poly-V belt).
  • REPLACE drive belt and VERIFY correct seating.
  • Pulley wobble.
  • VERIFY that no pulley wobbles during engine operation. Conditions causing wobble are: bent pulley, bent accessory shaft, rear face of pulley not seated flat against mating surface.
  • Excessive crankshaft end play.
  • REBUILD engine.
Joisey don't smell funny
78 Bronco Custom, 460/ZF5, Sniper upgrade, 3G, dual batt
On my 93 Bronco, and then my 95 F150, when the idler pulley started letting go, it would tear up the edge of the belt due to it allowing the belt to ride off the edge of the other components.
Reactions: GetBent4x4
1990 EB, 5.0
My belt tensioner and idler pulley are new. Last few months. I do have a slight wobble in the smog pulley
Reactions: miesk5
1990 EB, 5.0
Thanks Miesk.
Today I’m going to autozone to pick up a pulley puller and new pulleys for my smog and power steering. It’s the easiest fix I can think of based on the troubleshooting guide. I’ll see how that goes first.
Reactions: canuckistan97
1990 EB, 5.0
Replaced the smog pulley, but it still has a wobble. Must be the shaft. Thought about eliminating it, but I still have cats connected.
I’ll get a puller tomorrow to replace the power steering pulley.
When I re-seat the new poly belt then start up, the belt comes off the crankshaft pulley and smog pulley both by one notch. I may try to replace the crankshaft pulley as well but not sure that will make a difference
1990 EB, 5.0
Discussion Starter · #8 · (Edited)
Rank has a rubber damper around it, I’ve had toyota loose a crank maybe this is happening as well
Back in July I replaced the timing chain cover, timing chain and Harmonic balancer. Haven't had any issues so I don't think the rubber damper is going bad.
The problem has me vexed so here's my next step. Since I think the slight wobble in the smog pulley is part of the issue I'm going to bypass it and get a shorter belt like folks have suggested. Put new pulleys on the power steering and crank shaft, just for good measure, and see how it goes.
Right now I have the fan and shroud off to give me room to replace all the pulleys, just waiting on the pulleys, shorter belt, to arrive now. Hope to have it back together before end of the week, with fingers crossed this solves the issue. I'm reading threads now on the details of bypassing the smog pulley. Looks like I need to do something with the hoses.
Reactions: miesk5
Yo Siggy,
This is as close as I can offer right now:
Removal, Belt in an 88 5.0; "...I tried an 89.5" first, 2 inches shorter than stock and it was too long. So I went back hoping for something about 88 or so and all they had was a 87.5. It was a bit short and a royal pita to put on but it is running fine. A lil tight but it should hold till I get an 88.2 which they can order." by fright88
Removal, Belt Part Number 882K6 in an 88 5.0 by Barbaric35
Removal, Belt Part Number in an 89 5.8; NAPA Belt Part # 060825*by Cucamongan (Scotty) at SuperMotors.net
1990 EB, 5.0
Discussion Starter · #10 ·
Yo Siggy,
This is as close as I can offer wight now:
Thanks again miesk5. After combing through all the threads I've ordered an 87 and a 89 inch belt from Gates so one of those should work. Figure the belt tensioner will allow for some room to play with. I plan to remove the pulley and go with the shorter belt. Seems like the logical choice if emissions aren't a factor.
I've also read about folks getting their CATs clogged if the air pump isn't forcing things through, so I'm planning to cut out the CATs with a sawsall, to avoid any issues, and install a piece of straight pipe with seal clamps in it's place. I'll see how that goes, but may have to get it welded.
Reactions: miesk5
1990 EB, 5.0
Discussion Starter · #11 ·
Well when I got home today I went and looked under the truck to see how much exhaust pipe I'd be replacing. It was in that moment I realized this job would be bigger than I cared to take on. Especially for zero performance gain. So I'm taking the easy way out and ordering a new SMOG pump. I cancelled all the belts and exhaust pipe stuff I ordered earlier. Found a pump on Amazon for $165, Replacing the pump, combined with all new pulleys, should hopefully fix the belt issue. Should have it done by Thursday. I'll let you all know how it goes.
When you install the PS pump pulley the bracket and pump must be mounted to the engine. Then you can clean and lube the PS pulley shaft and the pulley hole. Then use OEM Tools 27031 pulley installer to install the pulley. You can't install the pulley with the setup off the truck as it fights you.
1990 EB, 5.0
Discussion Starter · #13 · (Edited)
So it seems the issue was/is the power steering pulley. I put everything back together and the belt stil jumps one notch over. But now I’m sure it is the PS pulley. With the truck running I can see how the belt come off the ps pulley and is further out on the fan pulley which causes it to come off the crankshaft and smog pulleys.
here’s the problem. I can’t get the ps pulley seated any further on. There is room on the shaft, and clearance from the bolts, but my ps puller/installer won’t push it any further and I think it’s breaking screws.
Auto part Automotive engine part Metal
Any suggestions? Is this a tool problem? If I could just get the pulley on another 1/4 - 1/2 inch I’d be set. So I think I’ll go buy a tap tomorrow and a propane torch. Should be able to remove the pulley, heat it up and slide it on. If not I’ll go the tap route.
1990 EB, 5.0
Discussion Starter · #14 ·
So last night I tried to heat the pulley up in the over and tap in on with a rubber mallet. Didn't work. Bought a torch and tap set this morning on the way to work. This afternoon I'll try to torch the center. If that doesn't work I'll have to open my $60 DeWalt tap set to see if I can fix the threads.
1990 EB, 5.0
Discussion Starter · #15 ·
And now the saga comes to an end. I fixed it. I bought a tap and die set and tapped the 3/8 hole in the PS pump. This created additional room to thread in the removal tool. Then I could push the ps pulley I’m far enough to align the belt. Huzzah! All is right with the world. If you have a belt issue, suspect the power steering pulley first.
Reactions: miesk5
1990 EB, 5.0
Discussion Starter · #17 ·
Dont use the harbor freight pulley remover/ NOT installer. If you ever tried it; it sucks at pulley installations.
I used a cheap one I bought for $17 off amazon.
1990 EB, 5.0
Discussion Starter · #18 ·
Well crap. Now the power steering pulley cracked and came off on me. Of course the belt went with it. Stranded on the roadside. Got someone coming to pick me up to go to autozone for a puller, pulley and new belt.
Any ideas why this would crack and come apart? Thought I finally had the issue solved.
1990 EB, 5.0
Discussion Starter · #19 ·
Wheel Auto part Tire Rim Automotive tire
Tire Automotive tire Auto part Automotive wheel system Wheel
Yo Siggy,
Have you heard a chirping type noise?
A chirping noise from the accessory drive belt that is more noticeable at idle than at higher speeds may be caused by a power steering pump pulley (3A733) that is out of alignment.
The misaligned power steering pulley causes the accessory drive belt to chirp as the belt enters it on an angle on 4.9L engines, or after it leaves the power steering pump pulley, travels over the water pump pulley (8509) and enters into the crankshaft pulley (6312) on an angle on 5.0L and 5.8L engines. Verify that the chirping noise is coming from the entrance to one of these two pulleys by listening through a length of rubber hose or another stethoscope-like device.
If the chirp has been isolated to one of these pulleys, then correct this condition by aligning the power steering pump pulley using the following service procedure.
NOTE: Accessory drive belt chirp not corrected by this procedure may be caused by a damaged pulley or bent accessory shafts. Steady pulsation of the drive belt tensioner (6B209) indicates this condition. Observe each pulley in the system for runout.
  1. CAUTION: Do not sand the edges of the drive belt or apply lubricants or dressings. These are only temporary fixes and may damage belt.
    Clean the accessory drive belt (8620) with mild soap and water to wash away oil or other contaminants.
  1. On some models, it may be necessary to remove the fan shroud (8146) to allow for proper installation and operation of the power steering pulley puller and installer tools.
  1. Using Steering Pump Pulley Remover T69L-10300-B and Steering Pump Pulley Replacer T65P-3A733-C set the power steering pump pulley hub to within ±.010 inch of being flush with the end of the power steering pump shaft.
  1. CAUTION: Damaged accessory drive belts should be replaced before proceeding to Step 4. Only use a closed-end wrench to lift the drive belt tensioner to avoid possible damage. A wedged screwdriver will crack the pulley or the housing.
    Operate the engine (6007) at idle for five (5) minutes to see if chirping noise has been corrected. If not, proceed to Step 5.
  1. Select a direction and move the power steering pump pulley at .50mm (.020 inch) increments in that direction. After each move (increment), remove the tool and operate the engine for five (5) minutes. If chirp fades, alignment is being achieved; if chirp increases, reverse the alignment direction. Continue moving the pulley until the noise is eliminated.
  1. Reinstall the fan shroud."
1 - 20 of 25 Posts
