So i have been thinking about putting chromoly shafts in the dana 44 when i do my sas. I have read a few bad things about Yukon shafts, so i am woundering which shafts would be the best to go with.
I got a qoute of $525 Shipped with spicer joints and full circle clips from a vendor on Pirate, which is more in my price range, but not sure of there quality.It is kinda of confusing, Motive gear bought Alloy Usa's stock and Ron Stobaugh part owner of alloy has moved to motive. Omix bought alloy/precision gear so the alloy name is dead. the Ten factory name is the new name in quality axle shafts w/ a ten year warranty. Same quality specs that alloy had now with a great big company to support it.
Your probably right, they might come at some point.Damn that stuff aint cheap either :shocked You could buy won tons for that kind of lute.
Yea I hear bad things ever since randy's took them over. Over on PBB everyone had some bad things to say. Not to say others weren't happy, but there were a lot of pucker faced customers there for awhile.moser sucked
yukon sucked
Warns were the best at the time. but Randy's bought out Warn's axle devision, so who knows now.
Alloy USA's were good with no question warrentee, they were sold out and I think are not ten factory?
dunno who else is out there.
That is the path I am going to take, I built what I have because of what I had at the time. After you figure $200 in the brakes, $200 for the new warn hubs, $100 in u-joint & ball joints and say another $100-$150 in misc seals, bearings, lugs & lugnuts. I should have went that route to begin withYour probably right, they might come at some point.
With your wheelin style, i dont think you need a D60. I wouldnt want to beat up that truck either!I think i will be fine with a 44 with the wheeling that i do, just looking for a little added insurance.
So what do you guys thik about Superior since Warn shafts are no longer around.
This. for the win.You guys have to remember too, if he switches to a dana 60 front, he now runs the issue of changing over to conventional leaf, or grinding and welding the set up for coils. On top of that, he would have to purchase a panhard bar, necessary brackets for the dana 60, then would have to 8-lug the rear, buy new rims, all new u-joints (because the joints in the driveshafts certainly will not be direct fitment to 1-tons)
Moreover, if he wanted to do it correctly (meaning instead of buying conversion joints) he would have to change out the flanges or yokes that he has to accept a 1-ton driveshaft that would accept full 1-ton u-joints.
He is on 37's. A set of premium alloy axles are by far the simplest route to go. I do agree a dana 60 for pure out of the box strength and a stronger platform, it really pisses me off when people say "Oh go 1-ton! buy a dana 60!" and they don't think about all the work that has to go into it. Just something for you guys to think about...
this is what i was getting at to on the dana 60 to . a super build dana 44 with RCV's is still cheaper and easyer than a 60You guys have to remember too, if he switches to a dana 60 front, he now runs the issue of changing over to conventional leaf, or grinding and welding the set up for coils. On top of that, he would have to purchase a panhard bar, necessary brackets for the dana 60, then would have to 8-lug the rear, buy new rims, all new u-joints (because the joints in the driveshafts certainly will not be direct fitment to 1-tons)
I didn't mean you, and I wasn't singling anyone out specifically. Just tired of seeing people post "GO ONE TONS! OMGZ LARGE TIRES MUST GO DANA 60!"this is what i was getting at to on the dana 60 to . a super build dana 44 with RCV's is still cheaper and easyer than a 60
yea, and these are through JBG as I recall.With your wheelin style, i dont think you need a D60. I wouldnt want to beat up that truck either!
Steve ran regular old Yukons in his with a detroit & 38s and didnt break his, so i think youd be fine.
Superiors are good, but a buddy went thru hell when he warrantied his before theyd actually give him a new shaft.
Warns are still around, but they are now called Yukons "Extreme" line. Im told they are even better now.
