yo,
Ford Motorcraft
See diagram below
Item Part Number Description
1 Fuel Delivery Module (Part of 9H307)
2 In-Tank Venturi Filter (Part of 9H307)
3 9A299 Resistor Assembly
4 High-Pressure Pump (Part of 9H307)
Fuel Tank Sending Unit
With the sending unit float arm in the empty stop position, resistance should be 15 ohms (below E). With the sending unit float arm in the full stop position, resistance should be 160 ohms (above F). The fuel gauge should read empty at 22.5 ohms and full at 145 ohms.
fuel indicating system components are functioning properly and inaccurate indications continue, check the fuel tank for damage which may have changed the fuel tank sending unit mounting angle and/or damaged the fuel tank sending unit. Make sure the fuel delivery module (FDM) is the correct model for the vehicle and that the FDM is not contacting the bottom of the fuel tank. Also inspect the vent hoses for kinks or obstructions.
usually buy Genuine Motorcraft parts at Amazon Ford dealers; they are VG at delvy
Search for motorcraft 9A299 bronco
examples
1996 FORD BRONCO 5.0L V8 : Fuel/Air : Fuel Tank Sending Unit MOTORCRAFT Part # PS22 {#F0PF9A299DA, FOTZ9A299DB} $127.79
http://www.rockauto.com/catalog/raf...NCO+5.8L+V8+Fuel%2FAir+Fuel+Tank+Sending+Unit
same for 1996 : FORD : BRONCO :
5.8L V8 : Fuel/Air : Fuel Tank Sending Unit Price MOTORCRAFT Part # PS22 More Info {#F0PF9A299DA, FOTZ9A299DB}
