Bilstein 5100 and Rancho 9000 are some of the higher end shocks recommended around here.
Fox shocks are supposedly designed for weekend/offroading toys and you may not like the ride otherwise.
I decided I want Rancho 9000 series adjustables for when I eventully get new shocks.
You adjust them by sound, not sight.
Turn the adjust knob all the way to the left. Then each click to the right is a different setting.
I think it's softest on the far left and gradually stiffer as you turn to the right.
That's how I remember reading about them, but I could be wrong on the direction.
I'd have mine set to soft unless I go offroading and then I'd set them more firm.
Or for the rear, I'd set it firm if doing any trailering.
These are the unconfirmed part #'s I collected for my notes, for my '94 Bronco.
$236 Shocks Front inner Ranch RS999117 -
Rancho RS9000XL Series Shock Absorber - RS999116
$236 Shocks Front outer Ranch RS999179 -
Rancho RS9000XL Series Shock Absorber - RS999179
$236 Rear Shocks RS999116
Rancho RS999116 Rancho RS9000XL Shock Absorbers | Summit Racing
$12 Rear Shock Axle Shim Kit RS8125 (may be Required on Rear Axle for Shock-to-Axle Clearance) -
Rancho RS8125 Rancho Leaf Spring Shims | Summit Racing
Supposedly they will rust a bit in salt environments, so make sure to paint (or maybe clear coat?) before installing them.
