Stitch's 95,
Yo Stitch,
I bought the 96 Bronco's 1/4 panel patch panels from MILL SUPPLY, Cleveland, OH
Their 95 body parts On-line Store site is
1995 Ford Bronco Tailgates | Mill Supply, Inc.
They were primed and of 18 gauge steel - exact fit around wheel well arch and packaged very well for shipping.
I ordered it on 6 JUN 2011 @ 1225 hours and received on 8 JUN 2011 !!!
S & H cost for both from Cleveland, OH to NJ was $12.xx
I use rust buster after removing rust to prevent further deterioration.
Inspect glass weatherstrip for grime, lack of lubrication. Clean ws with water/Dawn mixture, then clean water.
Ford recommends, "Use Silicone Lubricant C0AZ-19553-AA (jelly) or D7AZ-19553-AA (spray) or equivalent meeting Ford specification ESR-M13P4-A on the door and window weatherstrips whenever necessary.
Silicone lubricant helps avoid weatherstrip squeaks and retards excess weatherstrip wear from chafing between the glass and the weatherstrip. It also helps to retain glass alignment by reducing friction between the glass frame and the rubber weatherstrip.
miesk5 note, test the silicone on a regular styrofoam cup first; if the cup gets funky or melts, then the can or tube contans oil, a regular occurrence now, esp if from China.
More tg lube info:
Use Multi-Purpose Grease or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C106-B to lubricate door and tailgate hinges. Apply an even coat to all hinge pivot points as outlined in the maintenance schedules or when a binding or squeaking condition occurs..." I bought a can of Motorcraft Multi-Purpose Grease @ Advance Auto
I use DuPont™ Non-Stick Dry Film Lubricant with Teflon™ on the flocked edges that hug the glass.
"Take off the TG access cover and spray Tri-Flow in the tracks on either side so the regulator toggles slide up and down easy" by our late friend here JKossarides.
"The best grease for the slides & tracks is PTFE". by Steve83 )BANNED[
Is window regulator rusted badly? If so, clean & lube it with multi purpose grease.
Are Glass rollers ok?
