1 - 9 of 9 Posts
Anybody know when BFG last updated the All Terrain design? I have a set of 5 BFG ATs 33X12.50-R15. Two are worn out, 2 have 50% treat and 1 almost new (it was the spare - lol). So to have 4 tires that will pass inspection I found a matching tire (so I thought!) on CL. Almost new and seller claimed it also was a spare and never on the ground. The tire is in really good condition and has close to 100% tread - looks like it may have been on the ground once or twice. I'm not complaining about the tire condition - it still has the "blue" on the white letters, but I am questioning the age of the tire. The set of 5 I have are probably about 5 years old and they say "All-Terrain T/A" and the tire I bought supposedly newer, say "Radial All-Terrain T/A". Plus the new tire has a less agressive side lug design. Not much but definately less agressive. The ATs on the BFG website say "All Terrian T/A" - no "radial" in the raised white letters. So, can anybody tell me the difference between an AT that says Radial All-Terrain T/A vs. an AT that simply says All-Terrain T/A?? Both are radials!
ate lug
88 + 96 broncos, 96 F250
Youre comparing an A/T to an A/T K/O. It is mostly the sidewall thats different, but if you compare the two, there is a very slight change in the tread too. The K/Os came out back around 2000-02, IIRC. Mine were bought new in early '04, and were K/Os.
You're correct. The "All-Terrains T/A" have a raised "K/O" (not white) on them. The "Radial All-Terrains T/A" do not. So the tire I bought must be 10+ years old!
Thanks! :thumbup
Oh well! It still looks in good condition and will get me through the inspection. It does not appear to have any weather checking or dry rot at all.
What does the dot code say?
Interesting. Checked the DOT stamps and here's the result -
Tire I just bought: 1 1 9 (March 1999)
Tires I have: 4 3 00 (October 2000)
So I was off on the age of current tires too! Funny that these tires are so close to the same age. The changeover to K/O must have been in late 99 or early 2000.
1 - 9 of 9 Posts
