ok Ive done small suspension lifts and ive decided im going to go straight to big lifting
here is about the end size I want
http://youtu.be/cxMvq8mopeQ
I havent really been able to find any blue prints but building up the frame first I thought it would be neat to just run the tube frame into the stock one and adding support plates on the stock frame but that would be way heavy,... so I thought I will just go with a solid tube frame using somewhere around 1 5/8" wide by 1/4" thick but we carry 2" by 1/4" on hand at work so im not sure witch is better
second I think 2 1/2 ton rock wells will be a good choice to run tractor tires? o and defiantly hydraulic steering
third transmission and transfer case im stumped here ive never built to this size scale and it's in the grey area of what to use I don't know if a c6 would be heave enough or the np 205 can with stand the power as well or just to get a custom case made I know it depends on what you're doing with it but im just making it a straight mud runner and the engine will be in the normal place maybe drooped down some but not heavily
fourth suspension Im not sure if I can just run one set of coil overs all around and build a 4 link set up only two places I know of so far to go to, to get shocks of that size are king, fox, and voodo and im still not sure what to do
fifth and final engine to run with? mine has a 351w block that I would like to turn into a stroker engine but the 460 build up would have more torque but more weight so suggestions are highly welcome
here are some of my resource sites and threads
helpful on rockwell building:
http://pirate4x4.com/forum/showthread.php?t=784718
rear radiator setup:
http://www.pirate4x4.com/forum/showthread.php?t=603541&highlight=radiator
shocks:
http://voodoooffroad.com/pricing.html
http://www.kingshocks.com/products/purerace/monster-pure-race/
large truck suspension in general:
http://www.therangerstation.com/Magazine/winter2007/monstertech.htm
hydraulic conversion:
http://www.4wheeloffroad.com/techar...c_steering_system_conversion_guide/index.html
http://pirate4x4.com/tech/billavista/PR-Hydro_Steering/index2.html
rockwell parts:
http://www.easternsurplus.net/5ton_spares.html
:beer
shocks:
rockwell parts:
:beer
