121 - 126 of 126 Posts
1989 Eddie Bauer 5.0
Discussion Starter #122
Well, since it looked like the PO had replaced the stock fuel pump relay, I don't think it ever occurred to test it, like I did. It was bad. I installed a new one and to my pleasant surprise, when I turned the key, I heard the fuel pump whir to life for a second, then cut off! I turned the key more, and it roared to life! So I shut everything down, started cleaning up, and crawled under the Broncosaurus to say goodbye to the blue wire!
https://flic.kr/p/2jrbHs8 I then cut, soldered and heat shrinked it, as well as the wire to the frame mounted fuel pump that I found.
https://flic.kr/p/2jrantw . Now I have to decide how to deal with the missing fusible links. But at least now it drives again. (Side note, I found my speedometer gear drive)
https://flic.kr/p/2jranwC
Discussion Starter #123
Somehow, I convinced the wife I needed to drive the Broncosaurus to work for shakedown run purposes. Good thing, too. I think the tailight short was tied to the cigarette lighter. To you young folk, it's the accessory plug. The plug doesn't work now. Which means I had to use a speedometer app on my phone, instead of the GPS. I'll sort it out later 😉
electrical gremlins are my kryptonite
same, one of the reasons I went back to a bullnose. a lot less stuff to worry about, and that's all Im having to work on right now, gauges, power windows, high beams, radio, etc. But it runs and drives fine.
Reactions: dash_cam
1989 Bronco XLT, 451W, C6
Yo Dude,
Inspect relay sockets for corrosion, etc.
Following from 1989 Bronco/Truck
EVTM, Emissions (yellowish/red book cover) & Pre-Delivery Manuals, Partial via mrnewland1 in Google Drive @
1989 Service manual - Google Drive
Slow scrolling, so download for faster viewing and to seee table of contents.
View attachment 164413 View attachment 164415
I like that wiring diagram better than the Haynes version! Thank you!
Thanks for this link.
