41 - 52 of 52 Posts
that's a lot of oil
Discussion Starter #41
Core support is officially out! Time to get things cleaned up and put back together.
Sent from my SM-G930V using Tapatalk
that's a lot of oil
Discussion Starter #42
Did some more cleaning today and started to put in the new headlights. Other then the core support, all the other metal looks ok, so I washed, dried, and installed new speed clips. It was nice to get 25 years of dirt off the headlight support, lots of areas you could never get to with it installed. I hadn't planned on new lenses, but it's just so easy with everything out so I pulled the trigger.
that's a lot of oil
Discussion Starter #43
More progress! Just about all the parts are in, so next steps will be clean up the engine compartment, refinish some metal parts (brackets, battery tray) in chassis saver, then put it all back together.
that's a lot of oil
Discussion Starter #44
Got the water pump off today (and thermostat housing), it was really gross. I'll need to spend some time cleaning before putting the new one in.
I also attempted to pull the coolant plug from the engine block and it promptly rounded itself. It's a 1/4 inch pipe plug style, so I have no idea how to get it out. Any thoughts?
that's a lot of oil
Discussion Starter #45
Updates!
Working on my saginaw swap. It's surprising to see how small the OE pump is, it's no wonder they struggle with bigger tires.
Took a load to the metal recycling center
Happy to see that my core support mounts are solid.
Getting the old mounts off was a B!TCH. Took a big recip and a crowbar.
that's a lot of oil
Discussion Starter #46
Pump swap is done (mostly). Ignore the high pressure line, just sitting there after mock up.
that's a lot of oil
Discussion Starter #47 (Edited)
Got in a bit more work recently. Finally got the engine coolant plug out, what a pain...
Other then that delay things are going back together pretty easily. New core mounts are in along with the new support. All hardware is being replaced at the same time. Finally starting to look like a truck again!
that's a lot of oil
Discussion Starter #48
Not much action here for a bit, but I have a bunch of parts with my local sand blaster, should have them back tomorrow ready for coating. Nothing fancy, just a brush on product. It's mostly random brackets, the mount for the airbox and the battery tray. Other than surface rust and junk they're in good shape.
I picked up a nicer heater for the garage too, so it should be easier to get out there and work more often.
that's a lot of oil
Discussion Starter #49
Progress on parts! Here's the steps from straight off the truck, to after sand blasting, to rust protected and painted.
Sent from my Pixel 3a XL using Tapatalk
Looks good. Didn't see your post about the block drain plug until now - I had the same issue. Used an extractor bit from the Irwin set I bought. One in this kit:
It fit perfect in the drain plug without any drilling. A little heat and it came right out.
that's a lot of oil
Discussion Starter #51
I used a very similar kit, but I basically had to drill all the way through the plug to get it out. I later tried the extractor on a smaller bolt I broke on the core support and it promptly snapped... Guess some of those bad Amazon reviews were right. Oh well, it served its purpose.
that's a lot of oil
Discussion Starter #52
Intake tray is back in and a/c parts are being test fitted. Need to figure out the large hose though, new part doesn't seem to match.
41 - 52 of 52 Posts
