1 - 3 of 3 Posts
I did a search but could not find a problem exactly like mine....so...The reverse lights and blinkers do not work, the hazards do work. All fuses are good, all bulbs have been replaced, the turn signal flasher was checked and works. Any ideas?...and yes before someone asks , the turn signal fluid level is fine.
crank trigger
Yes, but did you check the reverse light bearings? they might need replacing.
search, you #$%@! noob
mine did that intermittantly, never did find the exact cause of the problem, but i'm guessing it was a short in my trailer harness wiring...
1 - 3 of 3 Posts
