1 - 9 of 9 Posts
I'm replacing the blower motor on my AC bronco and I have the giant box loose but want to see how I get it out with the ac lines attached. I keep seeing posts about a step-by-step guide but can't find a working link.
Also if I decide to get rhe ac working someday should I replace the condenser with a modern one or can it take modern refrigerant? The rest of the parts (compressor etc) are missing so I'd be replacing them later on.
Thanks
Ah that worked. Thanks! I can't get one of the hoses off the ac condenser. Thinking of just leaving the condenser out for now
Yo,
We will work on the hoses later.
Ok, got a new motor from Oreillys that looks right but the fan wheel is an inch too small. The old one it 6 1/4 inches diameter and I can't seem to find one that size. Stock one if bent and wobbles so I'd like to replace it but not sure where to find one...
Yo,
Contact rockauto.com for the 78 HVAC Blower Motor
VDO
Blower Wheel Included?No
Connector TypeSplice
Flanged EndYes
Gasket or Seal IncludedNo
Hard Wired Or Plug InHardwired
MaterialMetal
Motor Diameter (IN)3.250
Motor Length (IN)4.875
Mounting Base Length (IN)4.125
Mounting Bolt Pattern Length (IN)7.875
Mounting Flange to End of Case (IN)2.750
Mounting Hardware Included?No
Mounting MethodFlange Mounted
RotationReversible
Shaft Diameter (IN)0.312
Shaft Diameter (MM)7.95
Shaft Length (IN)1.063
Shaft TypeSingle Shaft
SpeedsVariable
Terminal TypeButt
VentedYes
Voltage12
Alternate/OEM Part Number(s): 35572, C9UZ19805A, D20A19805A, D20F19846AE, D3TF19805AA, D3TZ19805A, D5DZ19805B, D5OZ19805A, D5OZ19805B, D5TA18565CA, D60F19805BA, D60Z19805B, D6DF19805B, D6OF19805AB, D6OF19805B, D6OF19805BA, D6OZ19805B, D6TF19805AA, E6UF19805AB, E8UF19805BA, E8UH19805AA, E8UZ19805B, E9UH19805AA
1 - 9 of 9 Posts
