1 - 12 of 12 Posts
jim at bloody knuckle garage is making radius arms again for the general public. not sure if this is old news but i just now found out. now i know they look very similar and i think that jim wants a little more for his. any reason to go with the new ones he makes vs the duff arms?
ate lug
88 + 96 broncos, 96 F250
I think he uses a heavier wall tube than Duff, i heard Duff only uses .250" vs his .313". Also he has the weld-on kit if you dont want to use wedges.
Beyond that, no other difference i know of. The only reason i wont order from his is because he is Facebook only, and facebook is the devil. Dammit Jim get a real website!
got an email from him earlier, 825 for the arms plus shipping. he makes a track bar, track bar bracket, upper and lower coil mounts, dual shock mount and coil springs. i assume with all the same designs. that being said, is there an advantage running a shock hoop over what duff has out now, and the springs he has are comparable to 6" deavers? im trying to see what i have offered to me to plan this out.
My Duff arms (ordered last week) were $825 shipped including the 2 degree bushings. I honestly did look to see what was up when you mentioned them, and also found the only place with any info was facebook. I know that it's becoming a big thing, but also think that you need a "real" online presence...
Honestly, is the .313 that much better than the $.250? Sure, it's 25% thicker, but why not use .500 then?
Can't speak to the weld-on pieces, as that is not the route I'm taking.
By the way, BNK? Are you thinking BKG? Just curious. Anyway, I've seen the 2" x .250" tubing break and bend more readily when used as link material on various trail rigs and very rarely have I ever seen the .313" DOM material bend and haven't seen it break. I've also visualized the vertical HAZ from tube to plate on my old design as a weak point so I now spread out the load more in an angled ending between plate and tube. 3/16" side plates can tend to egg out the 5/8" holes up front on heavily used trail rigs or rigs that are just heavy so I use the 1/4" plate to avoid any issues. The vertical plate not visible in installed pictures but it sits just behind the 5/8" holes on mine are fully welded and connected top and bottom not leaving any gaps like on my old design. I also now use a threaded heim bung in the end that will handle any of the long thread joints out there like "johnny Joints" if someone so desires.
Frame plate is all 1/4" as well.
Some other little differences in angles here and there, top/bottom/inner/outer/forward plates all start as separate pieces then are welded into shape as opposed to bent over the tube. This allows for a couple more feet of weld contact area making the plate/tube connection much stronger.
There are actually a lot of little differences I've done to make them stronger now evan as compared to the CAGE ones which were stronger yet than my even older design.
ate lug
There are actually a lot of little differences I've done to make them stronger now even as compared to the CAGE ones which were stronger yet than my even older design.
I have no doubt that they are beefy, as i have wheeled the crap out of my Cage arms for years now. :thumbup
Unfortunately i did bend one, but i have a plan to straighten/reinforce it so it wont bend again.
How exactly do you plan on straightening and renforcing it? I have bent one as well. I would like to straighten it out and renforce it because I'm pretty rough on $hit and I don't think bkg will warranty Cage arms.
ate lug
I went wheeling with a guy from MEB who bent his cage arm the same way i did, and he said he straightened it by chaining the axle to the frame, and jacking the bend out of the arm with a port-a-power (positioned between the arm & frame). Apparently it bent back really easy. Ive been busy with other projects so i havent gotten around to straightening mine.
1 - 12 of 12 Posts
