I am going to start tthe body work on my 79 bronco and i was wondering if anyone can give me info on who has the best quality pannels jeffs graveyard, LMC, NAtional parts,ect i have no exsperience in body work but i am doing alot of research and going to do it my self :thumbup
penis
Ummmmmmm hmmmmm no experiance in body work so you are going to weld, glue, duct tape, and bondo?????? I would say get the panels you seek have someone replace them (someone on here will lend you a hand in the welding area) and prep yourself.
thanks for the info i have some welding experiance in steel tubbing just minior though i have a mig and time to pratice unless someone else is near quakertown Pa who could give me a hand
I also tried to take it to body shops and nobody will give me a estimate they all keep telling me they only will charge me $75-$150 per hour they wanted me to give $2000 to start (this is with me purchasing the pannels) and it doesnt seam as though anyone really wanted to do it including 2 resto shops in my area i just keep getting fustrated cause im trying to set a budget for the project and its a bronco not brain surgery so i figure maybe try it
Age. Fac ut gaudeam
Mm.
This doesn't bode well. Be sure to practice.
G'Luck.
I disagree. Gotta get the experience somehow.
It really isn't brain surgery. Takes a good eye, some knowledge, and patience.
From what I've heard, the body panels are a huge pain in the ass to replace in some spots. I don't remember who, but somebody said they'd rather do and engine swap twice than replace their fenders again.
I have ordered some National Parts Depot body parts before (for a mustang not bronco) they seemed decent quality. Most of the panels are made by the same company over in taiwan or something anyways.
As for just starting off with body work, It is easy to learn how to do and incredibly hard to get good at. Just be sure to take your time, always ALWAYS measure a couple times before you cut, take your time because you will get angry and frustrated, be sure to use the proper tools, don't ever get angry enough to get the attitude "i will just hit it till it fits."
Be sure to take your time welding, go slow, space out your welds, and allow plenty of time for the metal to cool (so you dont warp your new panels). Definitely practice a lot on scrap panels that you might have or metal of a similar thickness. Practicing a lot before hand will make it easier.
Just for reference I started doing body work with zero experience. So far all the panels i have replaced have turned out pretty good. It just takes a lot of time to do properly.
yo,
Here is Body parts info; look for CAPA Certified;
The Certified Automotive Parts Association (CAPA) is a non-profit organization established in 1987 to develop and oversee a test program guaranteeing the suitability and quality of automotive parts. CAPA encourages competition in the marketplace in the hope that their program will ultimately reduce expense to the consumer and the industry while increasing and assuring part quality.
CAPA Data Base Search http://www.capacertified.org/partsearch.asp
Here is my Search today; I went thru the Ford, Bronco drill without inserting a Year;
do it yourself to see a btter view of the table Results
Then, when buying a panel, ask your parts source if they use the manufacturer and pn listed.
There were CAPA certified 1/4 panel sources up to abour 7 yrs ago in USA, Great Lakes area, but the company folded.
Certified Part Applications
Retrieved on 7/20/2010
Search Terms: FORD BRONCO
Manufacturer Part Description Make/Model Years Details AM Part # OEM Part # PartsLink
AP Door Shell R Ford Bronco 1987-1991 FD9300400-1R0C F2TZ1520124B FO1301113
AP Deflector Stone, Upper Ford Bronco 1987-1991 FD9200110-000C E7TZ17779A FO1092107
AP Door Shell R Ford Bronco 1992-1993 w/o Low Mtd. Swing Away Mirror FD9300400-0R0C F2TZ1520124A FO1301115
AP Door Shell L Ford Bronco 1992-1993 w/Low Mtd. Swing Away Mirror FD9300400-1L0C F2TZ1520125B FO1300113
AP Door Shell R Ford Bronco 1992-1993 w/Low Mtd. Swing Away Mirror FD9300400-1R0C F2TZ1520124B FO1301113
AP Door Shell L Ford Bronco 1992-1993 w/o Low Mtd. Swing Away Mirror FD9300400-0L0C F2TZ1520125A FO1300115
AP Deflector Stone Ford Bronco 1992-1996 FD9300110-000C F2TZ17779A FO1087122
AP Hood Ford Bronco 1992-1996 FD9300150-000C F2TZ16612A FO1230121
AP Deflector Stone Ford Bronco II 1989-1990 FD7300110-000C F1TZ17779B FO1087124
AP Hood Ford Bronco II 1989-1990 FD7300150-000C F3TZ16612A FO1230124
AP Fender R Ford Bronco II 1989-1990 FD7300160-0R0C E9TZ16005A FO1241129
AP-Procom Reinforcement, Grille Opng Ford Bronco 1992-1996 FD930093N-000C F6TZ8A284AC FO1220113
Cobra King Hood Ford Bronco 1992-1996 FD72001Q F2TZ16612A FO1230121
Cobra King Fender R Ford Bronco 1992-1996 FD72002RQ F2TZ16005A FO1241136
Cobra King Fender L Ford Bronco 1992-1996 FD72002LQ F4TZ16006A FO1240138
DEPO Taillamp L Ford Bronco 1989-1996 331-1916L-UC E9TZ13405C FO2800106
DEPO Taillamp R Ford Bronco 1989-1996 331-1916R-UC E9TZ13404C FO2801105
DEPO Lamp, Side Marker R Ford Bronco 1992-1996 331-1515R-UC F2TZ15A201C FO2551108
DEPO Lamp, Park/Signal L Ford Bronco 1992-1996 331-1612L-UC F5TZ13201AB FO2520116
DEPO Headlamp Assy, L Ford Bronco 1992-1996 331-1111L-AC F2TZ13008B FO2502118
DEPO Lamp, Side Marker L Ford Bronco 1992-1996 331-1515L-UC F2TZ15A201D FO2550110
DEPO Headlamp Assy, R Ford Bronco 1992-1996 331-1111R-AC F2TZ13008A FO2503114
DEPO Lamp, Park/Signal R Ford Bronco 1992-1996 331-1612R-UC F5TZ13200AB FO2521114
Gordon Door Shell R Ford Bronco 1980-1986 FDPU80DR1 E4TZ1520124A FO1301103
Gordon Hood Ford Bronco 1980-1986 FDPU80HD1 E4TZ16612B FO1230104
Gordon Tailgate Ford Bronco 1983-1993 FDBC83TG1 E8TZ9840700A FO1900106
Gordon Fender L Ford Bronco 1987-1991 FDPU87FL1 E8TZ16006A FO1240124
Gordon Fender R Ford Bronco 1987-1991 FDPU87FR1 E7TZ16005A FO1241122
Gordon Hood Ford Bronco 1987-1991 FDPU87HD1 F1TZ16612A FO1230117
Gordon Door Shell L Ford Bronco 1992-1993 w/o Low Mtd. Swing Away Mirror FDPU92DL1 F2TZ1520125A FO1300115
Gordon Door Shell L Ford Bronco 1992-1993 w/Low Mtd. Swing Away Mirror FDPU92D11 F2TZ1520125B FO1300113
Gordon Door Shell R Ford Bronco 1992-1993 w/o Low Mtd. Swing Away Mirror FDPU92DR1 F2TZ1520124A FO1301115
Gordon Fender R Ford Bronco 1992-1996 FDPU92FR1 F2TZ16005A FO1241136
Gordon Hood Ford Bronco 1992-1996 FDPU92HD1 F2TZ16612A FO1230121
Gordon Fender L Ford Bronco 1992-1996 FDPU92FL1 F4TZ16006A FO1240138
Gordon Fender R Ford Bronco II 1989-1990 FDRG89FR1 E9TZ16005A FO1241129
Gordon Hood Ford Bronco II 1989-1990 FDRG89HD1 F3TZ16612A FO1230124
Gordon Fender L Ford Bronco II 1989-1990 FDRG89FL1 E9TZ16006A FO1240128
Jui Li Door Shell R Ford Bronco 1980-1986 S0007D200AS E4TZ1520124A FO1301103
Jui Li Door Shell L Ford Bronco 1980-1986 S0007D100AS E4TZ1520125A FO1300102
Taiwan Kai Yih Hood Ford Bronco 1987-1991 FD-20027AQ F1TZ16612A FO1230117
Taiwan Kai Yih Deflector Stone, Upper Ford Bronco 1987-1991 FD-50037AUQ E7TZ17779A FO1092107
Taiwan Kai Yih Hood Ford Bronco 1992-1996 FD-20053AQ F2TZ16612A FO1230121
Taiwan Kai Yih Deflector Stone Ford Bronco 1992-1996 FD-50041AQ F2TZ17779A FO1087122
Taiwan Kai Yih Fender L Ford Bronco 1992-1996 FD-10062AQ-LH F4TZ16006A FO1240138
Taiwan Kai Yih Fender R Ford Bronco 1992-1996 FD-10062AQ-RH F2TZ16005A FO1241136
Taiwan Kai Yih Deflector Stone Ford Bronco II 1989-1990 FD-46043AQ F1TZ17779B FO1087124
TYC Brother Headlamp Assy, L Ford Bronco 1987-1991 Black w/bright trim 20-1609-00-9 E9TZ13008F FO2502105
TYC Brother Headlamp Assy, R Ford Bronco 1987-1991 Black w/bright trim 20-1608-00-9 E9TZ13008E FO2503105
TYC Brother Headlamp Assy, R Ford Bronco 1992-1996 20-1934-00-9 F2TZ13008A FO2503114
TYC Brother Headlamp Assy, L Ford Bronco 1992-1996 20-1935-00-9 F2TZ13008B FO2502118
William Precision Deflector Stone, Upper Ford Bronco 1987-1991 WL-295Q E7TZ17779A FO1092107
William Precision Deflector Stone Ford Bronco 1992-1996 WL-294Q F2TZ17779A FO1087122
William Precision Deflector Stone Ford Bronco II 1989-1990 WL-290Q F1TZ17779B FO1087124
William Precision Hood Ford Bronco II 1989-1990 WL-209Q F3TZ16612A FO1230124
55 Certified Part Applications Listed
I tthen select the OEM Part # and do a google on it;
Such as Tailgate E8TZ9840700A
and got a few results; best one is Rock Auto; @ http://www.rockauto.com/dbphp/x,car...NCO_4.9L_300_cubic_inch_L6_FI_Y_Tailgate.html
SHERMAN Part # CCC575712Q {#575712Q, E8TZ9840700A, FO1900106}
tailgate shell (CAPA Certified) Bronco 83-96 $215.79
LH/LT=left hand/driver side. RH/RT=right hand/passenger side. *Please refer to catalog description, not image shown in catalog, to choose LH or RH side.
and then a google for Sherman;
http://www.shermanparts.com/ecat/base/dropdowns.php?make=FORD&model=BRON&year=1978
CAPA CERTIFIED parts bear the seal of the Certified Automotive Parts Association (http://www.capacertified.org/) guaranteeing fit and quality equal to original equipment. These parts may be required if your insurance company is paying for the repair.
