why not?...would be fun to watch on the first yank attempt.:histericaDcSkater602 said:dont mount that on a stock bumper...
dc
especially if you're using the stock bumper. Not as important with, but still recommended for, 3/16 and 1/4" thick bumpers. Backing plate should be, at least, 150% the thickness of the bumper, and at least, 25% larger than the area of the bracketbnkrtstk said:If I were you I would use a backing plate behind the bumper when you bolt them up.
now that is a pretty clean looking bumper.cr69ml said:I'm not putting it on a stock bumper that would be kinda dumb ...hahahaha
It will be on this 1/4" thick c channel with a backing plate behind it and welded up.
redwagon said:meant how far does it stick out...one problem I ran into when i built mine was I didnt account for how far the grill stuck out...so I had to notch the grill to get the winch to fit.
Everytime I see that pic I think the fairlead should be mounted 3-4 inchs lowercr69ml said:
cool...thanks for the pic.cr69ml said:
This pic is straight into the front it is alittle high butthis is where I had to go, does it really make a difference. Half the time you are either to high or to low from the vehicle in front of you when you hook up. I f I am wrong please explain I am here to learn.ToddACimer said:Everytime I see that pic I think the fairlead should be mounted 3-4 inchs lower
