1 - 9 of 9 Posts
OUT OF BUSINESS / M.I.A.
Dustball said:
Unless you have an 80-82 front diff, you're not gonna be able to use it.
And why not? I'm not going to be using C-clips anyway. Won't the valve spring trick hole it in there too?
Stop making me look stupid :brownbag :drinkbud
Damager said:
AAAAHAHAHAHAHAHAHA!!!!!!!!!! and it's a HD50
must be the meds ............ :histerica
Thats the point. The 50 and 44 use the same spline in the diff. So the HD50 shaft will fit in the 44, and gives you a larger joint at the slip shaft. Less weak points.
Now the question is will the retaining shaft fit the C-clip housing :shrug
Mr. Smartass thinks I'm :wacko for trying :cry
shibby
I'm using the regular c-clip inner slip on my 44, works fine. Can't use the c-clip anyways, different c-clip location. You'll have to clearance the D50 yokes to get the same amount of angularity as the 44 yoke. I have no clue how the bolt-in retainer will affect things.
I'm :confused:
The D50 doesn't have the range of motion as the D44 shaft?
Or it will rub on the TTB arm?
This truck (daily driver) will max out at 33" tires and a 2" lift so I can live with the range of motion, I think :shrug
shibby
Fireguy50 said:
I'm :confused:
Yeah, there's so much beef there that the ears of the slip yoke side binds with the inner shaft at full droop, at least for me. I have more axle cycle range than most people do so you should be fine.
D50 on left, D44 on right
http://ylobronc.users.superford.org/chassis/innershaft.jpg
1 - 9 of 9 Posts
