1 - 8 of 8 Posts
I have AlLs,I have springs and adj bushings.
I have brake lines .
I have shocks.Pittman arms are easy.Where do I get drop brackets>>>>>>>
And do I need center hinge or just radius arm brackets or both?What the difference?
The brackets in the center are the axle arm pivot drop brackets.
What do you mean by front bracket kit?
If that's the kit that you bought then you already have drop pivot brackets. Yes it will allow you to raise the truck and you should only have to adjust your camber a little, though you may want to get 2* or 2.5* high misalignment camber bushings anyway (just incase).
I bought it piece by piece,adj bushings ,6 " coils ,Pittman ARM rear AALS,,,now all i think i need is the brackets,do they come with instructions?
If you buy them new then yes. Search eBay for some deals.
1 - 8 of 8 Posts
