21 - 25 of 25 Posts
Ford Hoarder
78 & 92
Also sometimes on these rear disc swap, I have had to remoove caliper to bleed it, then re-install.
Sounds like you found issue with MC though.
FSB Pimpster & Recruiter
Discussion Starter #22
UPDATE !
Hi Boys and Girls, Here is where I'm at right now.
Installed F350 Booster n M. cyl. bled system, everything is great until I start the truck and the pedal goes all the way to the floor, All hoses are good for vacuum and booster came with a new check valve. I believe that maybe my 4WABS Control module has air in the system, my only guess.
How can I be sure it's the module ?
Thanks all,
Allcrusien
Discussion Starter #24
@dash_cam yes sir, but only with the truck off. That's why I'm thinking bad ABS ABS pump?
Driving Stuff Henry Built
Did you adjust the rod coming out of the new booster? When I upgraded mine it was way too short of the box.
It's a Goldilocks adjustment. It's important to get it just right. Too short & you have a low pedal. Too long & the valving inside the MC doesn't open properly when you release the pedal. A little freeplay at the top is a good sign. On mine I was able to separate the MC from the booster far enough to make adjustments without undoing the lines. Be sure to tighten up the locknut when you are done.
21 - 25 of 25 Posts
