:whiteflag
Folks -
I have been lurking here a while and I got some excellent info (props to Shadowfax and TophersWorld.com!!!!) and help by searching this site, but I have a problem that I cannot seem to find an answer to. Here's the situation:
Vehicle: 1994 EB
I replaced front rotors, calipers, pads and bearings. Much of the brake fluid drained out, but the reservoir was never empty. I bled the brakes thoroghly (1/2 a quart). When I got ready to test them out, there was some pedal feel when the truck was off. After I started the truck, the pedal is soft all the way to the floor and then it locks up the wheels at bottom.
So, here's where I'm at:
1. I found a leak and fixed that. No more leaks as far as I can tell.
2. I bled some more almost a quart total.
3. The pedal is soft all the way to the floor, and then locks up the brakes.
4. "Pumping" the pedal does NOT build up feel or pressure. It ALWAYS operates as descibed at 3.
I was watching the reservoir while someone else pumped the pedal, and it looks like fluid is coming back into the reservoir. Is it possible that the ABS valve is jacked up and diverting fluid?
Any help is greatly appreciated.
KC
P.S. No dash lights at all. When there was a leak, the brake light stayed on, but once I fixed the leak, no more lights.
Folks -
Vehicle: 1994 EB
KC
