My pedal hardly has any pressure in it. I check the master cylinder and add fluid, it was empty. I pump the shiiiit out of the pedal to build pressure and nothing. I check under the bronco and there is fluid leaking on the driver side rear.
Check the picture and see if you can tell how hard this will be to fix. Sorry, had trouble getting that far under to get a better picture.
http://i177.photobucket.com/albums/w216/big_dippin/Bronco/BroncoBrakeLineLeak008.jpg
