1 - 18 of 18 Posts
I think so, Yesturday I heard from a guy that they used a different brake booster for broncos than the f series trucks. He told me that if I use one of those or an adjustable one, the brakes would work fine. Is that true
A Heavy wheel/tire combo and stock brakes just isn't going to give you good performance. Do the F350 upgrade, it really isn't that much more expensive than replacing the stock stuff.
You upgraded to larger tires and if you want it to stop better you need to upgrade your brakes.
I've never heard of an adjustable one, however I'm not the most polished tool in the chest. Anyway, the tire/wheel combo is an issue. The F350 booster will help. Just wanted you to rule out all possibilities.
My F-350 upgrade only cost about $25. Junkyard parts work as good as new most of the time.
Sometimes better these days with the foreign crap rebuilds most auto parts places get.
i run 39.5x15 tires. i do not stand on the brakes. i could stop faster with a 350 upgrade, but not easier.my guess is you have rusted pistons in the calipers. air/moister in the lines.same for the brake booster. if it is bad you get soft brakes. drums not set right.that were i would start.
1 - 18 of 18 Posts
