1 - 3 of 3 Posts
I replaced my ignition actuator, ignition switch, and the plug on the steering column under the dash and now my brake light won’t work unless I mess with the turn signals but the turn signals work and the hazards are doing the same as the brake lights where they don’t work unless I mess with the turn signals. Also I’ve already replaced the brake switch and it is not the problem.
It’s likely the turn signal switch, power goes there before the brakes and hazards.
1 - 3 of 3 Posts
