1 - 8 of 8 Posts
On my brake pedal there are two switches.....one on top that is threaded and I guess is for adjusting when the brake lights come on and the other is for what?
I guess the one I thought was for the brake lights is the speed control valve. What does it do?.....I'll search.
So if my brake lights don't come on till the truck is alreay stoping and the pedal is pretty far down....is this adjustable?
You might and not know it. If you do it's controlled by your turn signal stalk. See if the stalk pulls towards you or away from you.
Boy do I feel stupid.. I've had my Bronco for almost four years and never new it had a tilt wheel..
Lick my balls
That's funny. I had mine for almost a year, I believe, before I realized how it worked. Before that I was always scratching my head because it looked like a tilt, just couldn't figure out what the actuator was. The even funnier part was the first thing I tried was the signal lever, but it just seemed to me it would break. I'm sure if I had pushed it just a tad more it would have worked.
USAF C-17 Maintenance
Ditto. I knew it was a tilt when I got the 84 because of the the dealer door sticker build sheet said so, but it took awhile till I figured to move the lever all the way forward.
Adrianspeeder
1 - 8 of 8 Posts
