I've been steadily working on replacing the wiring harness in my '79 (using American Autowire kit). Looking at my brake pedal, there appears to be an OEM cylindrical shaped switch with a plunger that is depressed when the brake pedal is depressed. This is what the AAW kit provides a connector for, but I noticed that my truck also has another switch mounted a bit higher up on the pedal. It looks like this, which is listed as a brake pedal switch for my year Bronco in addition to the other type.
The other one that is also installed:
Do I need both? Why do I have them both?!
Reactions: Desert Bronco
Yes, my truck was originally equipped with speed control, long since defunct due to EFI and a change of steering wheel. I might see how difficult it would be to add the cruise back in using the EEC-IV built-in OEM stuff at some point.
With great expectation of sparks and torching the whole truck, I connected the negative battery lead to the Bronco and... there were no sparks. I opened the door and the dome light turned on. I turned the parking lamps on and the lamps illuminated. I had my wife depress the brake pedal and the brake lights turned on! I'd say great success and the other brake switch is not being used at this time.
Reactions: Shaker666
1979 Bronco Ranger XLT, 400m engine, C6 trans, D44 front with Dick Cepek manual locking hubs
as I have to work on the switches as well, the cruise control switch can be removed then, correct? at least if there is no cruise control left.
1978 Bronco Ranger XLT, 400/C6 92 K documented miles &1994 Bronco,XLT 85K original miles
I have both in my '78 as well. Cruise removed last week due to EFI plus I rarely use it in my modern cars.
