Question about brakes, I seem to have an issue with my rears - they seem to be doing nothing whatsoever! How I determine that - when I hit the pedal on snow all four tires should be locking, yet I can see in my rearview mirrors that my rear tires are still turning. Worse, if I try to hold the truck in place with front brakes on snow and rears on pavement the rear wheels will keep pushing the truck forward till either the rear hits snow, or the front hits pavement. There is pressure going to the wheel cylinders, system is properly bled. The pedal feels weird too, tis a bit soft but stops the truck just fine, then all of sudden halfway down the pedal travel it's as if I just lost vacuum assist and I run all manual brakes... Truck stops fine with obviously just the front brakes, however I'm trying to figure out what's the deal with the rears. I tried readjusting the rear brake shoes but only the driver-side star-thingie turns, and I'm not even sure which way to turn it? I'll be taking the propane torch to the passenger side tomorrow, hopefully a bit of heat and some tanking can get that one unstuck too. I believe what happens is I'm having too much fluid bleed off towards the rear so I can't build up proper pressure? Assuming I get the darn adjuster of the passenger side unstuck, which direction do I turn both adjusters to tighten up the brakes? Clockwise or CCW? Thanks!
