So, I first finished the install of my newly acquired/built up 429 at the end of November, and was thrilled at how it turned out. But, I've had a steady stream of problems since then, to the point that I've only been able to put 150 miles on the beast in that time. The motor runs great, that's not the problem, but it seems like everything else is deciding this is a good time to go out too.
So, here's my current problem: While messing with the transmission for most of January, and finally having it rebuilt (again), one of my rear wheel cylinders started to leak. Not a big deal. I bought new ones, but waited until I had the tranny back in and working correctly before I started that project. This morning I swapped in the new wheel cylinders and bled the rear brakes. My braking is now worse than it was. Previously, 2-3 pumps of the brake pedal were required for any real braking. Now it doesn't matter how many times I pump it, it just goes to the floor and gives me piss-poor braking. I re-bled everything, in the correct sequence (RR, LR, RF, LF), taking my time and making sure I had no air bubbles, and still no difference. I even propped open that stupid button on the proportioning valve. At this point I'm throwing tools across the shop and using colorful language. My guess is that the master cylinder decided this was a good time to join the long list of failed parts. Is there anything else I should be looking at???
My intent is to do the braking upgrade with the F-350/Thunderbird parts, but right now the Bronco is the only running vehicle I have. I am apparently going to have to drive it minimally and cautiously while I get my Mustang back on the road, and then park the Bronco (again) while I re-do the whole braking system.... :banghead
At this point I welcome any thoughts/theories/commiserations.
