I did the F-350/T-Bird upgrade about a year ago with good results. I then recently added the 1-ton rear brake cylinders and now the master cylinder is leading around the seal for the cap. It seems to just be leaking from the section for the rear brakes. Anyone have any ideas whats causing the pressure? Thanks in advance.
GKR,
I have just done almost the same thing as you.I have a d60 in the rear.And 2 piston calipers form d44 f250 upfront.My m/c cap is also leaking.Oh it's a 78 bronco.The booster and m/c is from a 78 F350.I bought it from rock auto.com I sent the 1st one back and they sent me another one.It too is leaking.Looks like from the front brakes too.Did you find a solution?
TIA
Tim
Wow, I had to read this a couple of times to jog the memory:toothless
I ended up getting yet another master cylinder and that one didn't leak.
This was on my 79 also. Sounds like the same swap as you've done.
