I Paid for this sh!t
none of my brake, turn signal, or hazard flashers work, i didnt know until about half way through my drive to work, as they were working, and just stopped. what do i do about this? are there fuses i can check?
ps: i do have trailer wiring hookups too
running lights? dont think i have any, headlights do work, yes its on both sides.
i did just go check my fuse box though, and i had like 3 15 amp fuses that are blown
im gonna run down to the local parts store and get more fuses
ok update, i could only get one fuse right this second, so i replaced the flasher fuse, now my drivers side flasher works great front and rear but my passenger side doesnt at all, but while its flashing my voltmeter freaks out like every flash goes to 8volts, i am thinkin i have a short to ground somewhere, do yall concurr
ok think i found the problem (btw its not letting me edit my posts, weird) anyways, my trailer wiring had gotten pinched between my hitch and my bumper, causing a short, so i just cut it off for now, problem solved, blinkers work again, now all i need is 3 more fuses to bring back brake lights tail lights and flashers
