If you don't have ABS, don't fight nature, let em' gravity bleed for an hour or two, with a clear hose on the nipples.i just recently did a brake job on my bronco ,new wheel cylinders and brakelines and now i can't get brake fluid to the rear axle could this be the proportional valve? any input would be highly appreciated
1990 ford bronco
stock, 351w
Crack the nipples and put clear hoses on them and wait
Even better idea Scorpionboy !do you have a vacuum pump? try and pull it with the vacuum.
