The oil dip stick tube was all rotted out, checked the oil and it cracked closer to the lower half. Can this be replaced? What do I have to remove to get to it?
Thanks
you have to pull the motor toss it over your shoulder and spin around three times
nah its easy...crawl under the truck look uip on the drivers side and you should be able to find where the tub goes into the block...get a good hand on it wiggle around and pull...it just slides into the block about 2 inches...go to a junkyard or napa or something and get a new dipstick w/ tube
dc
green ones make me horny
redwagon said:
my tube has a nut on the end were it enters the oil pan...if thats the case then you need to loosen it first.
that would make it easy to remove then. mine has the falred end that "pops" into place
