1 - 8 of 8 Posts
how have you all been removing the fwd 2 front seat bolt. went to take my seats out to get recovered and broke both front bolts :banghead . I know a easyout aint going to do it. can they be punched through and replaced with a nut and bolt or do I need to drill and tap it ?
Drill it out then put through bolt and tack the nut on is easiest
Forward Some Money
do you happen to remember what size ? thanks
Right off hand....I don't.
I'm thinking I drilled just over 1/4". When I drill, I drill a bit off center. I shoot for a "C' shaped remnant without hitting the original threads. Then collapse the bolt and unscrew it with either a tap or a pair of vice grips.
I spun the pressed in nuts, had to weld them in place then got the bolts out. May have to weld yours in if they spin while drilling.
1 - 8 of 8 Posts
