Anyone know, if a 88-91 bronco fuel tank will fit on a F-250?
I have a '91 F-250 with a 460, and would love to have the bigger bronco rear tank, instead of the stock 16g one.
Local # 40 Boilermakers
Im not real sure about it but I would say it would, a lot of guys run the truck tanks in bronco's for the ground clearance. If you do get one you will need the pump and sending unit to, so be sure to get the whole setup.
Yea, there is a few broncos being parted out near me, and I thought of maybe grabbing one.
Unless someone on here, close to me wants to swap.
shibby
Yup, it will swap. You'll need to use universal fuel tank straps and need to use an exhaust pipe reducer as an adapter to get the filler hose hooked up.
ok cool, so then if I keep this truck, i will do it.
