1 - 20 of 123 Posts
· Diesel Gynachologist
Finally started my cage
After finally getting my ass in gear (hard to do from last night) and driving 2 hours round trip last night to get a die. I dove head first into building my whitetrash fab roll cage. Its not much yet but stay tuned it should be mostly done this weekend if Im lucky
advice and inputs would be great while I can change things
gearrat said:
looks like a good start dustin..... :thumbup
anyword from scott on the trail run today?
havent talked to him today
· Premium 4 Lyfe - Way Back Staff
Got to agree w/Marauder... nothing like a solid "Oh sh!t" bar! :rockon
Marauder said:
I always liked this idea
I have that picture and might try and incorporate that into mine, not sure how it will work/look with my dash tho. we will see
Discussion Starter · #10 ·
it will be a full cage, front and rear. Im still undecided on what to do with the rear tho, not sure if I want it family stlye or like what you have damager. Im going to build the front first then decide on what to do with the rear. sucks cause my nice speaker box is porbaly going to have to go or be moved :banghead its in the damn way
· College User
For a cage can you use box tubing. I have no way of bending the steel so would have to cut and weld all of my turns. I want some cage in the 79 but am limited on budget.
Discussion Starter · #12 ·
please dont use square tubing, bottom line of you dont have the equipment to do it right dont do it at all or pay someone to do it for you.
· FSB's Resident A$$HOLE
i second what dustin said, remember this thing is meant to save your life and hold up a 4000 lb + vehicle. dont be cheap about it, do it right the first time and dont risk your life on something you dont feel fully confident about. and cutting and welding creates even more stress points and danger, wouldnt recommend it at all
wes
· College User
Cutting and welding does not effect the strength of it. If it is thick metal it should not be a problem, a winch bumper is a good example of this point. I have no bolts holding it together in spots only the welds. I will have to find somebody with a bender then.
· FSB's Bastard Child
Dustin...Why not build above or around the box. Unless you plan on upgrading the boom boom...You should build around it...Or conform to its shape and then you will maximize storage space.
Another consideration Dustin...
When I was drawing up the design for my soft-top, I thought that a cage would be the best support system for the top. Also thought the cage would look purty sweet out there exposed.
Just throwing this out there...
Get it together Pepe, that's what I want/ need to help protect my kids when wheelin'. :rockon
Cage is looking good Dustin. Keep up the good work! ! ! :beer
LFF... as much as I agree, better talk to Dave about the cage!
I haven't picked up a mig in years. :brownbag
1 - 20 of 123 Posts
