I recently purchased a 1993 5.8L Bronco and the cables connecting the battery, alternator, starter solenoid, and starter where just 50 shades of garbage. Absolute shambles repairs and splices everywhere.
Additionally, someone installed a winch, high power light bar, and a kicking sound system, all this running off a 90amp 3G Alt, with i kid you not, 8gauge wire for the alternator charge cable. This cable was running from the alternator to the back post on the start solenoid, along with the yellow 14ga wire fromm the three plug on the alternator. Also on the back post was a 6ga cable to the positive battery terminal, with an additional 6ga cable running from the pos battery terminal to the starter motor, which stuck me as an odd configuration. the winch, light bar, and sound system where wired straight to the battery terminals, which i have since disconnected.
These combined to a pretty large amp draw, which i believed to be the source of the Bronco dieing while driving in the city, but not on open roads, the difference between alternator output at solid RPMs and constantly being at idle in the city.
Ive removed the bad repairs and replaced the smaller cables for 4ga everything. i also have a 270 amp alternator ordered, with 1/O size Big 3 cables.
This is where my questions begin
1. How should all the wires be connected between the battery, alternator, starter, and starter solenoid? Because ive seen numerous ways all a little different on youtube and in forums that supposedly all work, and my arrangement is just not working.With a new optima yellow top battery, that i have had on a 10amp charger with a AGM mode that shows fully charged, i have some power when turning the (brand new) ignition cylinder to start, but the volt gauge on the dash reads about 10volts and the starter will not even crank once. This is the current routing and connection of cables and wires, please tells me if any of this is incorrect;
-Battery, positive terminal, one 4ga cable to the alternator stud, and one 4ga caable to the back post of the starter solenoid.
-Battery, negative terminal, one 4ga 9" cable to the fender, which i removed all paint from, its bare metal. a second 4ga cable down to the frame, where it passes through a metal bracket and the insulation is removed so the midpoint bracket acts as a frame ground. this same cable continues to the engine block, (hopefully) grounding engine to frame, battery to frame, and battery to engine, in theory.
-Alternator, there's a 14-16ga yellow wire that was routed to the back post of the starter solenoid originally, so thats where it remains, but that is my only reason for putting it there. the green wire runs over to the passenger side fender, and connects to a different wiring harness. the white of course goes from the three plug connector to the one plug connector also on the alternator.
-Starter Solenoid, the only connector on the front post of the solenoid is the 14-16ga red wire that runs to the start motor. everything else is on the back post, which is how it was before.
2. For the new Alternator i have coming in, i need a belt 0.5" shorter than the one currently on there, and im trying to find out the length for that. i haven't been able to find a diagram for the belt on the 5.8L with the smog pump removed, but i have found a diagram for the 5.0L with the smog pump removed that has the belt routed and shaped very close to mine. is there a information on the belt itself thhat i could go look at, or belt diagrams with lengths required for the 5.8L engine, with smog pump removed?
Will upload any pictures you guys need as soon as i can.
