1986 Bronco, 04 Superduty axles, 40" Milestars, 4.8LS, 4L80E, NP241
After scouring the forum for the past couple of days, I decided I would post my custom soft top project. Similar to Wileec's top with some ideas from other tops thrown in. The general goal was to have a top that required minimal drilling in my body, allowed headroom for my passengers but still kept that fastback looks. Similar to how the Jeep LJ fastback soft tops looked. First step was to find an old hardtop to cut up and use as a frame for the top to mount velcro and snaps to. I found one for $50 locally that had a broken window. Once I got that I cut it down roughly to get an idea of the shape I was looking for, while leaving extra room to be trimmed later. I built a jig to hold the top in shape so that I could build the majority of the framework and center section of the top while it was on my trailer vs 6 feet in the air on my bronco.
I took some measurements in the bronco and found that I wanted the "peak" of the top to be roughly at the location of the 4th rib in the top. I built some supports and used a piece of angle I had laying around to make a jig to locate my support bow.
I ordered some boat bimini hardware and some 3/4" EMT conduit. I will have to drill out the bimini hardware from the 7/8 it comes in to the 15/16 OD that 3/4" EMT conduit is. Once I got the bow in place I noticed my original width for the top portion was going to be too wide to fit properly so I narrowed it from my initial 55" to 48". This will allow the sides to curve around the top and the bow.
I am hoping that It should maintain the tautness as it snaps into the rear window area. I put an old tarp up to verify the angle on the back was what I was looking for before I cut it and narrowed it for the top, and flared it out towards the tailgate. This will give me a decent pattern to cut the first piece from.
My fiancée was a seamstress for an awning company so we will be using some sunbrella awning material that should be fairly waterproof and then I will be adding waterproof spray on top of that. I bent the conduit by hand so it isn't the prettiest but it holds the angle fairly well and it's a detail that I can always come back and remake. More work to continue over the next couple days but it's been a fun project so far, now to keep up the momentum.
And finally a picture of my Bronco for reference:
