1 - 8 of 8 Posts
Hi. This is my first post to the forum. I've just purchased a 1982 Bronco, and need to get all new bolts and lag nuts (?) for attaching the hard top. I've been unable to find a kit on the internet, and my dealer wanted $14 for each bolt. Does anybody have a kit for sale, or does anybody have the thread type and size of the hardware (perhaps a Home Depot fix?). Thanks to all replies.
Austin Texas
or you could just go to a junkyard and pull the set off one there....
That way you know they'll fit
G
I pulled all the plastic, carpet, and plastic trim out of the back and lined it. I through-bolted the shell down with 4 - 5/16ths bolts, nuts, & fender washers on to side of the shell. I use 3 of the original bolts & body clips, one in the center on the top and one on each side of the cab. I did this to make the rear cargo area tuffer and easier to clean and faster/easier to get the top on and off (no plastic trim to remove/replace and only 3 of those fine thread bolts and clips to deal with). It may not look as nice but is more functional.
1 - 8 of 8 Posts
