281 - 288 of 288 Posts
Thank you miesk5. I am not finding the info you mention in post #5 of the thread you linked. :shrug
I tried searching but I am new here so please forgive me, I'm looking to buy a 78 in the next couple weeks. I have one that I want to buy that has the 460 swapped in and the guy says it needs a gasket in between the transmission and transfer case. It's a C6 and, I can't seem to find the right gasket for this, just want to find this before I buy it. I'd really appreciate it if someone could point me in the right direction or post the link to it on bronco graveyard. Sorry for the newbie BS.
Wow, I figured it out I believe, my bad.
I'm actually looking for a complete aluminum top with all the fingers and pins under it. My housing cover is very worn out and needs replaced in order to shift smoothly. 79 bronco with 400 mod, 435 manual trans.
1990 Ford Bronco Custom, 5.0L EFI AOD Manual Hubs
With all the posts on what trannys are what, or "what do I have" I thought it would be a good idea to make a total list for the full size fords. Just now I wipped this up to start off, but will keep workin. Please post any corrections ya'll see so I can edit.
For the engine listings. I'll break the shared bell housing patterns in {}.
Heavy Duty Automatics
Model: C6
Type: three speed non electronic
Years:
'66-'90 F-series
'78-'89 Bronco
'91-'96 ('97?) F-2/3/superduty
Engines:{300, 302, 351w}, {400, 351m, 460}, {6.9L, 7.3L IDI}, {352, 360, 390, ect.}
Fluid:
Pre '77: Type F
Post '77: Mercon
Display: PRND21
Pan 17 bolts "Utah" shape
Ratios:
1st 2.46:1
2nd 1.46:1
3rd 1.00:1
Trans code: K
Model: E4OD
Type: Electronic Four speed Over Drive
Years:
'90-'96 Bronco,
'89-'98 F-Series
Engines: {300, 302, 351w}, {460}, {7.3L IDI}, {7.3L PSD}, {5.4L}
Display: PRN(D)21 w/ overdrive lockout switch
Pan: 20 bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
Model: 4R100
Type: Four speed, Rear wheel drive, and 100(x10)lbs of torque
Years:
'99-'01 F-150's (rare)
'99-'04 Lightning's, F-150 7700'
'99-'03 superdutys
'03-'04 gas superdutys
Engines: {5.4L, 6.8L}, {7.3L PSD}
Pan: 20bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E (gas), 9 (diesel)
Model: 5R110 “Torqshift”
Type: Five speed, Rear wheel drive, and 110(x10)lbs of torque
Years:
'03-'04 6.0L
'05-'07 Superdutys
Engines: {5.4L, 6.8L, 6.0L},
Display: PRN(D)321 w/ tow haul lockout switch
Pan ?
Fluid: Mercon SP
Ratios:
1st 3.09:1
2nd 2.20:1
3rd 1.538:1
4th 1.00:1
5th 0.71:1
Trans code: B
Light Duty Automatics
Model: AOD
Type: Four speed non electronic
Years:
'85-'93 F-150
'85-'89 Bronco
Engines: 302
Display: PRN(D)D1
Pan ?
Fluid: Mercon
Ratios:
1st 2.40:1
2nd 1.47:1
3rd 1.00:1
4th 0.67:1
Trans code: T
Model: 4R70w
Type: Four speed, Rear wheel drive, and 70(x10)lbs of torque
Years: '94-'07 F-150
Engines: 302, 4.2L, 4.6L, 5.4L
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: U
Model: 4R75E
Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque
Years: '04-'07 F-150
Engines: 5.4L
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT)
Manuals
Model: M5OD-R2
Type: Five speed Mazda Overdrive
Years: 88-96 Bronco, F150s
..........97-03 F150s
..........05 F150 (v6)
Engines: 300, 302, 4.2L, 4.6L
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
1st 3.90:1
2nd 2.25:1
3rd 1.46:1
4th 1.00:1
5th 0.80:1
Construction features: External Ribs in square patterns
Trans code: M
Model: SROD
Type: Four speed overdrive w/ push down reverse
Years: 80-83(4?)
Engines: 300, 302
Fluid: ?
Display:
P..R..1..3
U
S.....2..OD
H
Ratios:
1st 3.25:1
2nd 1.92:1
3rd 1.00:1
4th 0.78:1
Reverse 3.25:1
Construction features: Aluminum, shifter near back
Trans code: B
Model: NP-435
Type: Four speed non overdrive
Years: 80-87?
Engines: 300, 302, Your mostly gonna find it behind a 300.
Display:
1.2
3.4.R
Construction features: Cast Iron w/aluminum top plate, shifter in top, PTO Pass side
Fluid: 140w
Ratios:
1st 6.69:1
2nd 3.34:1
3rd 1.79:1
4th 1.00:1
Reverse 3.25:1
Trans code: A
Model: T18
Type: Four speed, non overdrive, non syncro first gear
Years: ?
Engines: 300, 302, 351, 460
Fluid: ?
Display:
1.3
2.4.R
Construction features: Cast iron throughout
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code: F or P
Model: T19
Type: Four speed, non overdrive, syncro first gear
Years: ?
Engines:460?, 6.9L, 7.3L
Fluid: ?
Display:
1.3
2.4.R
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code F or P
Model: ZF5
Type: Five speed heavyduty overdrive
Years: 87-99 F2/3/450/superduty
Engines: 300, 351, 460, 7.3
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
S5-42 (Diesel)
1st: 4.14
2nd: 2.37
3rd: 1.42
4th: 1.00
5th: 0.77
Reverse: 3.79
S5-47 (diesel)
1st: 5.08
2nd: 2.61
3rd: 1.53
4th: 1.00
5th: 0.77
Reverse: 4.66
S5-42 and S5-47 (gas)
1st: 5.72
2nd: 2.94
3rd: 1.61
4th: 1.00
5th: 0.76
Reverse: 5.24
Trans code: 2
Model: ZF6
Type: Six speed heavyduty overdrive
Years: 99-06 F-superduty
Engines: 5.4, 6.8, 7.3, 6.0
Fluid: Mercon
Display:
R.1.3.(D)
L.2.4
Ratios:
L 5.79:1
1st 3.30:1
2nd 2.10:1
3rd 1.31:1
4th 1.00:1
5th 0.72:1
R 5.23:1
Trans code: 6 (diesel), 5 (gas)
Adrianspeeder
Hey adrianspeeder i was looking for some information for my Bronco transmission and I have something to add. For the AOD transmission you can add a 1990. Mine is a little odd i would say, it is the "Custom" model. You can also add that it is a 14 bolt pan. Great information you posted!
