1 - 18 of 18 Posts
Driving my bronco today, stopped at a stop light, went to take off nothing happened. Gave her some gas and all she did was stall. Felt like tranny was stuck in reverse (when it stalled, it jumped backwards), but I hadn't put it in reverse all day. By the time it got to AAMCO, we could roll it (wouldn't move before). They said they would call me when they found the problem, but I was hoping that you guys could help soften the blow. Has this happened to anyone else? If so, what kind of price am I looking at?
Oh yeah, the tranny's a M5OD. Thanks for any help.
yep
same thing happened to me...90 full size AOD tranny. 1700$ transmission relacement. Hope yours is somethin easy and cheap.
Recon!
College User
How do you have the m5od, did you swap it? yea the rebuild it 1500+ so good luck.
Well, If the repairs do cost me that much, what are my options? I mean, what transmissions were offered with the 300 that isn't going to cost me an arm and a leg? I have an old manual tranny from a '78 F250 sitting at home, would it bolt up? Otherwise, I might just roll this thing off of a cliff... but in its current condition I would have to be going backwards... nothing has been easy with this thing
OUCH!!
ok first off do not I repeat do not let aamco fix your tranny they are the crapest place in the world and will rip you off. They warrenty is crap and they do shitty work. I would take it somewhere else maybe to some place that you deal with alot but I repeat do not let aamco fix your tranny.
Well, aamco was the only place i knew of in the area. Later I found another transmission shop right down the street. I had the guy at aamco put on paper that he would give me a free estimate and that if I decided not to get it fixed there, everything would be put back the way they found it (didn't want them giving it back in pieces). Trust me, if I had the time or the space to swap out a tranny, I would do it.
A new or rather rebuilt M5OD should be about $750. Most places want about $250 for R/R work. If you replaced the clutch stuff plus a new slave it should add about $300 on the high side. I would think $15-1600 on the high side.
College User
You can put an e40d, which was the factory tranny, or the m5od which is in 97+ f-series trucks. Can prob get a rebuilt one from somebody for around 500$. Raf might still have his, or somebody else.
hates EVERYTHING!
I was wondering if someone was gonna chime in with this...I thought "Hell no!" soon as I saw aamco's name....phuck aamco they screwed me too!:mad: Ask around, find a indipendant tranny shop that others around you have good experience with...and don't be suprised if signed paper or not, they find a way to try and charge you for something....:shrug
Cadillac of Men
is the M5OD the mazda manual trans that kinda looks like a ZF?
if so, they do infact have many problems. my friend has one behind a 300 in his F-150. he lost some fowards gears, the place rebuild his entire trans, but the problem was just shifter forks/rails. make sure its not the shifter that is broken before they charge for an entire new trans.
and if its not the mazda, good luck.
Discussion Starter #13
Well I went to AAMCO this morning and they told me that the tranny was shot, clutch needs repaired, and the flywheel/pressure plate need resurfacing. Very pissed off, I towed it to a ford garage and they told me the same thing. Both said that it was going to be just short of $2000 to fix. I am starting to hate this Bronco.
:mad:
:shocked
another_ford stated "I am starting to hate this Bronco."
:twak :boxing
Isn't that blasphemy on this board? you might, maybe should be banned for comments such as that??
j/k
:D
tranny swap
Be wary of trying to swap the tranny.I had the same pos 5 speed in my 88 and swapped in a t18.I paid $300 for the tranny,bellhousing,slave,clutchmaster,shifters,floorpan,and 5.0 throttle body.Then I got an 11" clutch for $150.Resurfaced flywheel with spacer shim(normally $50 my cost)FREEBIE.Then I bought the front and rear driveshafts for an 88 Bronco with the C6(C6 and t18 are within 1 inch of each other in length)$150.Add in all new u-joints at $10 each.I had to make a custom tranny mount and modify the shifter so I wouldn't hit the dash when I put it in granny low or the center console when I put iy in reverse.I did all the labor myself with the benefit of having a shop to do it in.I also get a disount on all the parts.If you are unable to do the swap yourself,you are probably better off finding a shop that will swap in a used m50 for you.If that is the route you go make sure you get it from a reliable yard so you don't pay someone to install a bad tranny.Good luck.
Tastes Like Chicken
another_ford said:
[BI am starting to hate this Bronco.
:mad: [/B]
How much do you hate it? If you give it to me, I promise to kick it every day. I may even try to find some mountain goats to molest it, for a small fee.
mnewbern said:
:shocked
no, we all hate out broncos--that's what brings us together as a group :thumbup
Discussion Starter #18
Well, maybe "hate" was a bit strong. "annoyed" would probably fit better. But I still don't think that I'm going to get rid of it any time soon.
1 - 18 of 18 Posts
