Alright Heres the truck:
1991 Bronco
Rebuilt 5.0 with less than 6,000 miles
Fuel injected ... everything is stock
E40d
Battery Tested good (2 days ago)
New terminal connectors (1 day old)
New Solenoid to Starter cable (1 hour old)
Starter Tested good 3 Times back to back to back (made sure it got hot)
Bypassing the solenoid using the two large post on the solenoid
Cleaned all connections with wire brush
The problem:
The power is getting to the starter and you can here it click but the starter does not turn and the motor does not turn.
Disconected the belt to make sure none of the accesories were frozen and the starter still did not turn and the motor did not turn. You were still able to hear the starter recieve power and the 4gauge wire I was using to bridge the solenoid was getting warm.
The truck had this problem 2 days ago and my brother was able to clean the terminals and then the truck ran. It sounded a little funny with what seemed to be the ticking of a header leak (damn summit shorties). Since it was parked that night been, It wont start again.
The starter has been moved around to make sure there wasnt a dead "spot".
Thanks for the help guys
1991 Bronco
E40d
The problem:
