1 - 12 of 12 Posts
I really need your help guys heres the problem I go out to start my bronco and its 22 degrees and she won't start. I check the fuel pump reset switch and it was disengaged so i reset it and try again but the car still will not start what do I do.
1995 ford bronco 5.0L
I dont know if it matters but i had gotten the muffler replaced the day before maybe the mechanics ****ed something up?
Pull codes from the PCM first and see what's going on ~ there are numerous threads on "How To" pull codes and code # explanations can be copied FREE from Ryan McCormick, aka Fireguy50 who owns www.fordfuelinjection.com and www.rjmtechnologies.com ~
I would use the "search tool" up above and see if you can find a thread with a similar problem with remedy so as not to duplicate info etc.
Good Luck ~ :thumbup
I dont know but i think its definetly that theres no gas getting to the engine cause the fuel shut off switch was disengaged but after i turned it on it still wont work . YOu hear the engine trying to start and I cant even smell gas. Is there something else that you have to do when you reset the switch?
Zombie Hunter
you should hear the fuel pump prime when you turn the key to the "on" position.
There should be a whine, it's the fuel pump priming the fuel system. Check your fuses, your fuel pump relay, and the wiring running to and from the fuel pump.
Zombie Hunter
if you have power to the pump, and the pump still isn't priming, it's either a bad connection to the pump, or the pump itself.
1 - 12 of 12 Posts
