Hello all,
I have a 86 EB, 302 FI, AOD.
I was replacing the fuel filter on Fri afternoon and after I finished, the bronco will not start,
I have checked the inertia switch, that's not it as I can hear the pumps working, etc. the only thing of interest, is that when i tried to relieve the pressure on the fule lines by opening the circuit on the inertia switch by lifting the tab, nothing happened....
with the switch hooked up, the pumps work etc, but when lifting the tab, nothing happens, I have reset it many times and still nothing..
do you think the switch could be bad,,?
I have replaced the relay switch, and have started the vehicle by jumping the posts with a screwdriver.
I have replaced the ignition switch, no luck there either,,,
I have Aux power, the buzzers and whistles come on and everything else works,,
I am honestly concerned, I have spent most of last night and all of today trying to figure this out....:banghead
could it be a short?,
if so where is the most likely place it could be?
