1 - 20 of 23 Posts
Is it possible, using your VIN, to find out exactly what your Bronco was built with at the factory?
· Super Moderator
yo!
yes; for the most part; some Codes still need to be interpreted..trying to do so for awhile now;
Build Sheet Information (Ford 999 Report) in a 79
Source: by 46079bronco at http://fullsizebronco.com/forum/showthread.php?t=139406
This 999 Report USED to be free by simply calling a Ford phone#; Miesk5 Note on 30 AUG 2011 I called Ford @ 1-800-392-3673 & Jeff said all have been transferred to Helms.
$15.00 for a "Standard" Sheet and $40.00 for a "Deluxe" sheet. Helms is Ford's Official Publisher for Ford EVTMs, Owner Manuals, Wiring Diagrams, etc.
Helms at shopfordgear.com
i called that number a few years ago for both my broncos but i lost the number....great post!
· Premium Member
I pulled my carpet to cut an access hole for the fuel pump and ran across my build sheet yesterday.I had no idea it was gonna be there.
heres a few i have found and the ford papers i got back for my 79 free wheeling bronco.
[/IMG]
[/IMG]
[/IMG]
both my broncos came back with 2 pages of options
[/IMG]
· Premium Member
Just found the upper left corner of my build sheet under the rubber mat directly under the front bench seat. It was taped down with some black duct tape. Have no idea where the rest of it could have gone. It appears this was the first time the rubbber mat had been pulled up under the seat. I did get the one from Ford Customer Service.
· OUT OF BUSINESS / M.I.A
How ironic can it get , I just NOW removed my center console and saw the build sheet right there thru the 2" hole in the carpet, closest to the steering wheel. What an interesting place to put it, huh?......
is there any other clever places they like to hide them?
cuz i pulled my carpet out myself and no build sheet
· Super Moderator
YO B!
Locations vary because it depended upon who threw it in the Bronco on the production line vs. those who took time to place it same place for 18 years
Here is a compilation:
under the driver's or passenger side carpet
in the fiberglass top hidden behind the rear trim piece, driver's side in a 79 by Ziggy
under my carpet on the right side in the back in a 92 by M. Cardholder
under the carpet directly behind the front passenger seat, Under the cardboard spacer sheet/heat shield in an 88 by Dustball
under the drivers side of your front seat between the seat springs and the cushion in an 86 F 150 by Hoxviii
located underneath the carpet under the drivers seat and another in the back end underneath the carpet in an 88 by Xris
Ive found them in the back seat front seat Passenger floor Board and head liner...Gently feel your back seat for paper under the vinyl...Same with the back and then under the seats...Possibly under passenger carpeting rubber mat in a 78 by F1rocco
well unless they were ten kinds of meticulous when they put it back in that carpet hadn't been removed before
i had alot of trouble pulling my carpet out thanks to the poor condition my truck is/was in
i'll have a look through those other places you listed and see if i can spot it
thanks for the advice guys
1 - 20 of 23 Posts
