1 - 11 of 11 Posts
My guess would be yes. Just bolts up to the frame and I can't imagine ford changed the frame much if any between those years.
search, you #$%@! noob
iirc, didn't they start using the accordion frame horns on the '92's? i'm not sure whether that will affect fitment or not.
No. They mount to the frame differenty. The 87-91 style bumper mounted directly to the frame, but the 92-96 style mounted to brackets welded to the frame. If you can get it cheap enought and are good with a welder you can make it fit, but if you're paying someone to do it, i'd just wait until the right bumper came along.
Convicted Drunk Dialer
Not quite, the bumper is mounted to a bracket that puts the bumper pretty much right up against the frame.
The 92-96 front curves a lot more than the 87-91, so even if it did bolt right up, depending on the style of bumper, it might not look quite right.
Discussion Starter · #8 ·
yup the only winch bumpers i've found that i like are for 92's and up, and my fab skills are not great so i guess i will have to keep looking around. thanks for the help guys.
1 - 11 of 11 Posts
