1 - 4 of 4 Posts
Does anybody know if the little sheetmetal flag looking part is part of the pump kit for a BW 1356? I tore mine down the other day and the t case has eaten it. It was formed into one the gears and had been run that way for a while. I cant find a part name b/c all of the exploded views I have found only show part numbers and no refference to what the part numbers are actually called. I am thinking it is part of the pump.
Thanks 351w500
Wrenching for a Livin'
thats an extremley common problem. I would bet a good ford dealer has it in stock
yo,
Try Rockland Standard Gear - Bronco/Ford truck new & rebuilt transmissions & transfer cases & parts
"...To place an order, select the part that's right for you by using the "Part Lookup Guide" (on the left) and then use the pull-down menus to make your selections..."
Select Electr or Mech Shift..1356
1356 Manual Shift Parts Break-Out Diagram w/nomenclature
Source: by Steve83 @ http://www.supermotors.net/clubs/superford/registry/media/249572_1
IF THE IMAGE IS TOO SMALL, click it.
1 7045 Shaft Nut
2 7B368 Output Shaft Yoke Washer
3 7052 Oil Seal
4 7B215 Yoke to Flange Seal
5 -- Extension (Rear Spline) Cap, Bearing (Rear Yoke/Flange) (Serviced As Part of 7085 Assembly)
6 7085 Extension Assembly (Rear Spline) Cap Assembly, Bearing (Rear Yoke/Flange)
7 7A443 Bolt and Washer Assembly (1989 and Later)
8 -- Flange (Rear Flange) (Serviced As Part of 7B214 Assembly)
9 7917 Ring, Snap
10 7025 Bearing
11 7917 Ring, Snap
12 7100 Shift Collar Hub
13 7127 Caged Needle Bearing
14 7A010 Plug, Pipe
15 7917 Ring, Retaining
16 7D164 Lockup Hub
17 7D126 Spring, Lockup
18 7106 Lockup Collar
19 7177 Sprocket, Drive
20 7A210 Hose
21 382486-S Clamp, Hose
22 7A291 Transfer Housing to Case Bolt
23 7E215 Retainer, Pump
24 7A152 Cover, Pump
25 7A149 Housing, Pump
26 7A250 Pin, Pump
27 7A205 Spring, Pump Pin
28 7061 Output Shaft
29 7100 Shift Collar Hub
30 7A398 Front Planet
31 7C122 Ring, Retaining
32 7A153 Ring Gear
33 7A098 Filter, Oil
34 -- Gear, PTO (with PTO Only)
35 7917 Ring, Retaining
36 -- Ring, Retaining (Part of 7B215)
37 7166 Case Deflector Gasket (with PTO Only)
38 7165 Transfer Case Cover (with PTO Only)
39 381673-S Bolt (with PTO Only)
40 7034 Vent
41 7E440 4WD Indicator Switch
42 -- Setscrew (Part of 7E440)
43 -- Fork, Reduction (Serviced As Part of 7289 Assembly)
44 -- Facing, Shift Fork (Serviced As Part of 7289 Assembly)
45 7289 Ford Assembly Reduction
46 7235 Roller, Cam (Service As Part of 7289 Assembly)
47 -- Pin (Part of 7289)
48 7C430 Facing, Shift Fork
49 -- Retainer (Serviced As Part of 7289 Assembly)
50 7289 Fork Assembly, Shift, 2W-4W
51 7240 Shift Rail
52 7219 Shift Fork Spring
53 7C349 Spring, Detent
54 7C191 Bushing, Detent
55 7F063 Cam, Shift
56 7288 Shifter Shaft Seal
57 7B106 Lever, Shaft and Pin Assembly
58 7005 Case Front
59 -- Pin Dowel (Part of 7005)
60 7L027 Oil Pan Magnet
61 7917 Ring, Retaining
62 7061 Output Shaft
63 7177 Sprocket, Driven
64 7119 Thrust Washer
65 7917 Ring, Retaining
66 7A029 Chain, Drive
67 -- Yoke (Serviced As Part of 7B214 Assembly)
68 7005 Case Rear
F2TZ-7210-K 4X4 Shifter Assembly (Mazda R2, ZFLD)
F2TZ-7210-N 4X4 Shifter Assembly (E4OD)
F2TZ-7210-P 4X4 Shifter Assembly (T18, C6, AOD, ZFHD)
F2TZ-7B051-A Control Rod (Mazda R2, ZFLD 7.25" OC)
F2TZ-7B051-E Control Rod (E4OD)
F2TZ-7B051-C Control Rod (T18, C6)
F2TZ-7B051-D Control Rod (AOD)
F2TZ-7B051-B Control Rod (ZFHD)
1 - 4 of 4 Posts
