2nd mouse gets the cheese
so i searched and read some treads but couldnt find an answer to the question to which t case is stronger the 1345 or 1356?
thanks
Discussion Starter · #2 ·
some specs on my rig 89 bko frame 4.10 gears 1986 460 and 4speed with a bw 1345 and im in need of a rear dl and money is tight and i have a bw1356 w/a dl just curious if its worth waiting for the money to get a dl for the bw1345
OUT OF BUSINESS / M.I.A
Can you please go back and translate all that? It's like reading the fricken ingredients to Chinese firecrackers...........
yea thats my bad
specs
89 bko frame
1986 460 w/4 speed borg warner 1345
im in need of a rear drive line and money is tight
i have a bw1356 with a drive line so im just curious if its worth waiting for the money to get a dl for the bw1345 or put in the bw1356
hope that helps
Unless you're doing the Darien Gap or the Paris/Dakar, I don't see a problem with the 13-56.........
Rest in Peace Friend...
Both the 13-45 and 13-56 are chain-driven, with similar low-range ratios (about 2.7:1) and similar strength. I see no problem using the 13-56 with the 460, since that was a factory option on the larger trucks. In fact, I am using the 88 460 and stock 13-56 undre my 84 Bronco. JSM84
cool thanks guys :beer
