1989 Bronco XLT
351W
C6
BW1356
Manual locking hubs
First time (about a year ago):
I used 4L to pull a boat trailer out of my back yard. When I was done, I put the transmission into "N" and shifted the transfer case back into 2H. When I was backing up my drive way, the transmission/transfer case quit sending power to the rear wheels for a moment and then grabbed and barked the rear tires.
Second time (Couple of months ago):
Third time (last week):
I was driving to work going about 40-45 mph when I felt the transfer case / transmission pop a couple times under deceleration. Then, as I was driving it yesterday, the Bronco started that same grinding noise under deceleration. I pulled into the parking lot, where I was headed, and parked. I left it for a couple hours. When I got back in I shifted into 4H then back into 2H, and then drove home without incident.
Does anyone know what could cause this intermittent problem?
351W
C6
BW1356
Manual locking hubs
- Anytime the Bronco is under acceleration, everything seems normal.
- If the transmission was put in reverse, you would hear a horrible grinding noise and the vehicle would just roll forward as if it were in neutral.
- Anytime I was traveling faster than 20 mph and tried to decelerate, I would hear the grinding noise and it would just keep rolling as if it were in neutral. Then I would press the gas pedal to raise the rpms and the vehicle would jolt when the rpms of the engine caught up with the wheel speed.
- In park, the Bronco would not roll forward (just like it is supposed to do) but it would roll backward just like it was in neutral.
- The best way to describe what was happening is something in the drive train was acting like a 1-way bearing. a) As long as the engine was trying to push the wheels forward, everything was normal. b) Under deceleration, the engines rpms would drop to an idle, the vehicle would coast as if it were in neutral, and the transmission/transfer case would grind. If you gave a little throttle, the engine’s rpms would catch up the rear end and jolt the vehicle. c) If you put the transmission in reverse, you would here the grinding noise and the Bronco would roll forward as if it were in neutral.
